The 522 pound front end loader is probably why I didn't have any wheelies.
Exactly. However, even with draw bar protruding out from under pumpkin at rear, the tractor hits equilibrium at a fairly shallow angle (sketch on paper, if you don't follow). You can never walk the tractor up beyond where a straight line drawn thru axle center and to load (log) goes tangent.Bro - not all draw bars are created equal. The main reason that old Ford/Johnnys (and there was another one too but can't properly recall right now) had problems was because the draw bar was mounted way back under the rear axle. The axle was essentially the pivot point allowing the tractor to walk right over on itself. Case and a few others had the draw bar pulling from in front of or even mid section of the tractor. This would only allow the front tires to walk up until equilibrium took place - pulling the front down, just as hard as it is trying to pull it up.
Where did BS go? I miss his insight.Backwoods was the oldest. Still out there scrounging somewhere, I suppose.
When given the choice between following the forum rules or going on his merry way, he chose the latter.Where did BS go? I miss his insight.
I'm still 22 in my head. I plan on staying that way.
... then one day you start wondering who the old guy in the mirror is. Surely, it can't be me.Good luck with that,we all think we are still 22 but one day you will wake up and find it's just not true.
