maple1
Keep remembering though that you were talking about a once-in-5-years event. I don't mind using a couple of cords a couple times a year. That's me though...
Im going to look into that, I just didn't want to get a portable and then have a bunch of extension cords running through the house. But being able to just plug it in to a outside wall socket and turn breakers on from inside sounds like a good plan.
Me either. I wired the generator outlet in when I was renovating the downstairs (all new Sheetrock) so it was fairly easy. Also, with the interlock switch I can energize the entire panel and turn off certain stuff if I wanted to.
Folks around him last power outage that didn't know better, had bad fluids flowing up in their yard as a result of thinking their power to their grinder pump meant things would move away from home.. . .
In all, the first five years we lived in our house, we were without power for several hours a day, monthly,,,,, going 12 hours without power was basically a 2 to 3 time a year event. Then, 4 years ago, we had a storm that put us out for days and I finally broke down and bought a generator. Since, we haven't been without power for more than 2 hours in the worst of weather,,,,, simply because they did some tree trimming.
In all, it's good to be prepared, but unless you are disabled, or have a setup that somehow does not allow a portable unit to make ends meet on a minimal level, many people are going overboard with the whole house generators.
pen
How did that work out? Did she mess with a portable generator? I trained my wife on using the snow blower when I was laid up once, but....technically leaving my wife without power for 14 days
She sounds like a real trooper, to carry on one-armed like that!
I'm like a few others who have come to understand how simple life can be and how little emergency electrical power is actually needed to cover a grid outage, even one lasting several days.
Conclusion: live simply, have a small generator with a transfer switch to run refrigeration, lighting and electronics, and "enjoy" the adventure of a power outage.
2 generators? That's what I do. Run the big one once in a while for water.Any suggestions about how to get the "juice" needed to start and run the well pump if we are using a small generator to run the rest of the small house?
Thanks velvetfoot. A neighbor gave us his old generator because it would not power his well pump. This sounds like the answer- buy a small one new for constant power, and start the other one up for showers, etc. How do you hook them both up?2 generators? That's what I do. Run the big one once in a while for water.
I have an generator interlock on my panel. It powers both legs through two breakers. I have a generator inlet on the outside of the house. I plug the big 240v. generator into it. I can also plug a 120v. generator into the same inlet. I rigged up a plug for the 120v. generator such that it feeds both legs. I also throw the breakers on any 240v. appliances. That includes especially the well pump and electric water heater which come on when they want. I'm not sure what would happen if both legs of a 240v. load were fed by one leg: I'm thinking nothing would happen, but I don't know for sure, yet.Thanks velvetfoot. A neighbor gave us his old generator because it would not power his well pump. This sounds like the answer- buy a small one new for constant power, and start the other one up for showers, etc. How do you hook them both up?
Could you put the well pump on a plug & receptacle setup, then when you needed to genny the pump just unplug it from the receptacle & plug it into the genny? Maybe with an extra short cord in between. A dryer plug setup should work - or a range, think they're rated for more amps. Or a genny plug & receptacle.
See post above.With some sneaky tricks I plan to backfeed both sides of my panel with my 120 volt inverter genset. Superior voltage regulation, clean power, and the ability for any combination of circuits to access the entire generator output. Just no 240 stuff will work.
I have an generator interlock on my panel. It powers both legs through two breakers. I have a generator inlet on the outside of the house. I plug the big 240v. generator into it. I can also plug a 120v. generator into the same inlet. I rigged up a plug for the 120v. generator such that it feeds both legs. I also throw the breakers on any 240v. appliances. That includes especially the well pump and electric water heater which come on when they want. I'm not sure what would happen if both legs of a 240v. load were fed by one leg: I'm thinking nothing would happen, but I don't know for sure, yet.![]()
And, what do you think will happen if a 240v device is turned on? My theory is nothing.
I'm not going to risk it. With the floating neutral issue things get very complicated. I powered my Lincoln 240 volt stick welder with a genset once. The genset puts out 240 volts through the 4 wire plug but the Lincoln only needed a three wire input so I made a cheater cord. Depending on whether I combined the ground and neutral, used just the neutral, or used just the ground, the cooling fan on the Lincoln would work or it would not work.
So appliances don't always act like you'd think. They are too expensive to risk leaving energized with that unexpected power of inphase 120. I know I won't be using the 240 appliance anyway and it is easy to flip breakers.
