I purchased a ton of TSC bagged hardwood pellets recently in Farmington ct. The bar code identifies as Curran from NY. They burn well and no clumping or klinkers. Very clean and dust free. Moderate heat. 254.00 a ton. I have a 10% off coupon I will use on another ton for the garage. House gets premium softwood only.How do you tell who the manufacturer is of TSC pellets? Is there a way to read the barcode? Local TSC has hardwood pellets. Bought a bag @ $5.29 to try out. If they are good, I'll buy more, but if they change suppliers, I'll try one bag before buying bulk.
This explains the terrible quality. What site is this btw?
GS1 Company Database, You enter the 12 digit code in the GTIN tab.This explains the terrible quality. What site is this btw?
I read this wrong; you are referring to USED animal bedding (missed that keyword). It sounds like a neat idea, but I'd imagine a lot of processing must be done to dry it out and sterilize it. The amount of energy output involved to reuse it for this probably doesn't jive for it to be economically feasible.It's good for the environment to convert used animal bedding into pellets! How can the quality be bad, as long as there are no bed bugs in the bedding?
It would be better for the environment if all of that used animal bedding went back on the fields where it was grown the first place (nutrient cycling). Then the farmer wouldn't have to buy fertilizer, which has a significant environmental cost associated with manufacturing, transporting, and applying it.You can burn some of the resulting pellets to dry the input. As long as it's heated above boiling point it's sterilized.
