sparklow said:I use a WineGard (sp?) HD1080 antenna, mounted in my attic on a mast I had, attached to 50' of cable which runs down to my basement and then attaches to my old cable system. Try it, you might like it - and you will save money.
richg said:Vonage will do phone service for $17.00 per month.
Badfish740 said:We're really tired of paying for lots of channels we don't watch, plus we're looking to cut spending any way we can so that my wife can stay home with our daughter instead of going back to work. All the money we currently throw away on satellite TV could be put to much better use. However, we do still want to be able to watch NBC/ABC/CBS shows as well as NYC media market local news and sports. According to www.antennaweb.org this might not be possible? Here is the information I entered:
Are there any buildings, steeples, towers, or other structures taller than four stories within four blocks of your location, airports within two miles of your location, and/or many nearby trees over 30 feet tall: Yes
Antenna Height: I entered 30'. My masonry chimney is 23' tall so it would be easy to install a 7' tall mast on which to mount an antenna.
They recommend a "red" antenna-channel selection given is as follows:
Blue-VHF WNJB-DT 58.1 PBS NEW BRUNSWICK, NJ 110°/21.2 miles away-channel 8
Blue-VHF WPVI-DT 6.1 ABC PHILADELPHIA, PA 215°/46.5 miles away-channel 6
Violet-UHF KYW-DT 3.1 CBS PHILADELPHIA, PA 215°/46.5 miles away-channel 26
High Bridge is located in a hilly area of Northwest NJ in a small valley that is about 48 miles west of the New York City network (NBC/ABC/CBS/Fox) transmitters. Our elevation is about 400' above sea level, but by using Google Maps (with the terrain setting on) to draw a straight line between my house and the Empire State Building where most of the transmitters are located, I can see that there is an 800' high ridge (400' higher than my home) directly in the way. The ridge is located about 3 miles east of my house. Is this the reason that no NYC stations are listed for my area? Is there anything I can do about it? Just for the hell of it I went back and changed the antenna height to 60' and only picked up one additional station in nearby Bethlehem, PA. Any ideas on what type of antenna or other hardware I could use in order to get NYC TV out here? Philly TV only is a deal breaker because we're NY Giants fans, plus Philly news only covers South Jersey.
saladdin said:Do you have cable internet (kind that uses coaxe)? If so, put a splitter on the cable before it goes into your modem. Run coaxe to your tv. You should get basic cable channels. If you morally object, then forget I mentioned it.
 but I have to believe that they're smarter than that?  I'd certainly be willing to try though-it would get me NYC news-I could still use the antenna to get Philly network TV to watch the Eagles get their butts kicked :lol:  mbcijim said:Hulu Plus plus Netflix is about $16/month. If you want even more choices throw in an Amazon Prime for about $70/year. Forget the antennae. I have a Roku box ($100) that enables all this. Most game players will work in substitute for the Roku. I just cut all the way back to the basic plan prior to cutting the cord altogether. Not sure how I'd watch NFL at the moment. That's the only sport I watch. Some of the sports have internet packages now. We wanted to watch Christmas Vacation the other day it was $.99 on Amazon Prime and the quality was at least equal if not better than DVD.
SlyFerret said:I personally think that the old OTA local network affiliate business model is approaching a point where in no longer works. I predict that within the next 5 years, we are going to start seeing local OTA stations shutting down because they aren't profitable anymore. I hope I'm wrong, but as internet streaming picks up, and becomes a more viable alternative to broadcast and pay TV services, it will be harder and harder for local stations to keep bringing in add revenue.
I actually just made one similar to that yesterday - My version had the aluminum foil backer board. Even just sitting sideways in my attic, I'm picking up all the channels I could with my roof antenna, but with a much steadier signal. Now if only I could hook up a rotor...Whitepine2 said:Badfish740 said:We're really tired of paying for lots of channels we don't watch, plus we're looking to cut spending any way we can so that my wife can stay home with our daughter instead of going back to work. All the money we currently throw away on satellite TV could be put to much better use. However, we do still want to be able to watch NBC/ABC/CBS shows as well as NYC media market local news and sports. According to www.antennaweb.org this might not be possible? Here is the information I entered:
(broken link removed to http://current.org/ptv/ptv0821make.pdf) Check this out don't laugh I did but am using one for the upstares TV and it works easy to make and cheep it's worth a try good luck Whitepine2
Whitepine2 said:(broken link removed to http://current.org/ptv/ptv0821make.pdf) Check this out don't laugh I did but am using one for the upstares TV and it works easy to make and cheep it's worth a try good luck Whitepine2
pyper said:Just a note -- that design only works (well?) for UHF -- i.e., stations higher than 12. In my parts we get VHF stations too, but that's not true everywhere.
Highbeam said:So to look at channel 4 you set your tuner to channel 50. Sort of tricky but your TV tuner probably keeps that information relatively secret.
