Well where to begin, I have a Whitfied Advantage pellet stove( have had it for 5 or 6 years) and the control board needed to be replaced this year.
I found a guy local that can fix them but it was going to be a month wait for him to look at it
so I bought a new one instead.
The problem that I am having and have had in the past is the stove just doesn't seem to burn right and soots the door glass up in a day or two, It gets black enough that you can just barely see the flame. The flame burns low in the burn pot most of the time and sometimes the pellets burn up fairly fast like there is to much draft, but with the glass turning black is this a sign of not enough draft?
The draft control doesn't really seem to have much effect on the burn anyway ( the pull out draft control on the side)
I have cleaned the stove like it should be before starting it up........blowers, chimmeny, vents removed the baffles and even have a tube that I use on the vacuum and feed it through the stove in all the hidden passages....etc
I have talked to a couple of different dealers and service men and get two different stories, One tells me that the glass soot is normal and the stove need to be cleaned out every 2 or 3 days , The other one tells me that the glass should not get that dirty ever and I should only need to clean it ever week (6 or 7 days)
The stove is vented through the wall with a clean out tee out side and 5 feet of pipe up the side of the house with a turn down at the top.
I run the stove on two or three most of the time as it is not our main source of heat, just enjoy the extra heat and helps cut down on the oil bill. When the stove is set on two the flame burns just above the burn pot and lower(sometimes it looks like it went out but always seems to come back)\
Can anyone tell me how this stove should burn when working right as I can't seem to get a straight answer from anyone around here.
Should it have a consistent flame and how long before the glass gets extremly black and how often do you have to clean out the stove(ashes and glass...etc)
Also the stove seems to be very hard to light, we use the gel firestarter.
Thanks in advance (sorry to be so long winded but I am starting to not like the pellet stove....
![Down :( :(](/talk/styles/default/xenforo/smileys/downer.gif)
