Hi all. I have a nice cascade I rebuilt, new everything and it's cleaned perfectly. It's running nice, but I dont seem to be getting anywhere near the burn time as advertised in the manufacturer specs. Mine is a 1995 model, and everything is new in the stove other than the control board and actual auger. I seem to only be getting 20 hours of burn time on a full load (60lbs). That's on low with the fuel trim all the way down. Manufacturer specs call for up to 40 hours. I am only buying tractor supply hardwoods or HD firesides, but I can't believe the difference is that much. Also, I have timed the auger time off and on and it seems to be very close to spec (like maybe even below spec mwaning it should be feeding less pellets). Are the burn times just that over stated by the manufacturer or are there any issues I'm overlooking?. I'm getting plenty of heat, was just hoping to turn it down a little more during the warmer days instead of shutting it off. Almost thinking I should replace the control board, but it seems to be running so well.
