I bought a Whitfield advantage II-T insert The stove lasted a day prior to the auger stopping. The feed light never comes on. I have Ohmed out the high limit switch, pressure switch, low limit, and air inlet high pressure switch with them all checking out properly per the service manual. I have powered the motor directly and the auger turns and seems to run fine. This leads me to believe it is the control board but I was hoping someone may be able to either confirm this or suggest something else.
Thanks
Kevin
Thanks
Kevin
