clemsonfor
Just finished loading, took maybe 5 mins with a few trips and finding the right pieces, several trips to the shed, door cracked while waiting. OK I closed bypass at 10:41pm. When I put it into bypass it was 740F(CAT probe temps, which is what all the temps I give are), 2 mins later it was at 800F. Some stuff is oak that was split this summer but from dead tree ( I know its no where near 20% but it was on top and split right size. The rest is elm that was cut/split this last spring so it should be close, also some cherry that is at 20% guessing from same time, and some 2yr oak css on bottom, so its not the best load but its not suppose to be super cold so I am kind of mixing what I have tonight burn. Just looked its 10:48pm and I am reading 980F. and I have cut my air back at this point to about 2/3 open, so I have closed it by 1/3. Its 10:50pm and I have a reading of 1090F. 10:55Pm and reading 1210F. 10:57 and its showing 1290F. At about 10:55 I see the secondaries at the top starting to kick of. There pretty constant and blue just burning at the top right now, not really dramatic, but with some of the wood I put in there im not really expecting the northern lights. And its 10:59 and about 13:05. I have had enough of sitting here watching this and I am going to get into bed. This is also with the blower on low, if I have it on high I am confident that this will not raise as fast. But I just turned it down to low as I loaded it cause it was blowing burning hot air in my face as I reloaded, some air from the sir around stove but more so it was blowing the hot @$$ air that was in the stove flooding out of the door at me![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
