Mr_Super-Hunky said:
Thanks for the info Goose. We do have three fans already installed at the ridge and the roof pitch is very steep (10/12) so I will actually be blowing the air UP and then the angled ceilings will divert the circulating air back down.
Well that is the way you are SUPPOSED to run ceiling fans in the winter - pulling the hot air up, and bouncing it off the ceiling so that it flows back down along the walls helps keep the drafts down. In the summer most people want to blow straight down to get the extra cooling the breeze provides... Since we have both extremes, and our fan hangs 6' down from a 12/12 pitch ceiling we needed something that we could reverse from the ground since there is no practical way to reach the motor and flip the direction switch on most fans.
Several people have had concers that a single stove of any brand may not be enough.Whether it is or not, I have not heard anyone worry that it may be too much heat!. For that reason, I too am a bit worried that we may be underpowered.
"Underpowered" is a question of definition - how much of the heat load do you want the stove to carry vs. your backup / regular heating system? What is your "comfort temperature"? Will you be happy if the stove gets you to that 90% of the time, but on the ten coldest days of the year, you need to bundle up inside, or use the backup heat to "fill in" the last 10 degrees? How cold does it actually get? Never having lived there, my mental image of "Flagstaff AZ" is more like a hot desert than New England, but that doesn't count for much - more important is what is your usual Winter low temp, how long does it stay that cold, and how many "degree days" of heating do you need? All of these sorts of questions are going to play into the power equation, and alot of them we can't really tell the answers to from where we sit.
The way I see it, a second stove may be worthless upstairs as all my heat is going there anyway.
You said your lower level floor plan is fairly open, would it be feasible to locate a stove near opposite ends or corners of the house? I would probably tend to say pick two stove locations like you were going with a two stove solution, and put a big stove of your choice in the better of the two. Run for a season or two, and decide if you need more heat, and if so, how much, then add a second stove of appropriate size in the second place if needed.
One thing to remember that full log homes have an incredible "thermal mass" in terms of insulation. Once they warm up, they can remain warm relatively easily...(So I am told).
I've heard they have good thermal mass properties, but I've also heard mixed stories about how good they are for "R-value" of insulation, and / or blocking air infiltration. I think mostly this depends on the exact construction technology used, and how well it was applied... I would say air infiltration is going to be your biggest concern.
Should I get the defiant or the new Lopi Leyden, would it be bad for the stove to be running all the time at say medium setting?, or should I possibly hold out for the upcoming monster equinox by Hearthstone?. Maybe that tank at 80,000 btu.s with a 4.0+ cf box would do the job.
Having any stove running 24/7 at a medium heat, or even a high heat that isn't over firing is fine, thats what a stove is designed to do. A soapstone stove especially works best when used for 24/7 burning. However, I think you are going to have some trouble doing this. 1. Your high ceiling is going to mean you'll have stronger than average draft, which is going to give you a tendency to over-fire, and the natural tendency of pine to give short HOT fires is also going to give you a tendency to over fire.
A couple of other folks have mentioned the idea of your looking into "Masonry Heaters" - the Tulakivi is one brand, there are others, mostly quasi-custom built for each home. In many ways they would be IDEAL for you, and I would reccomend looking seriously at them.
I may be putting a very expensive grand piano in the house so I am also concerned with humidity levels. I've read an outside combustion air kit will possibly prevent the home from getting to dry and stuffy. Any thoughts ?
An Outside Air Kit (OAK) is mostly needed to supply outside air in the case of homes that are very tightly sealed and / or have lots of other exhaust air appliances (such as a big exhaust fan on the stove) that compete for combustion air. Without the OAK, you "burn" room air, which is replaced by outside air infiltrating into the house - some folks see this as a good thing for bringing in "fresh air" The problem is that outside air is usually drier so you'd possibly have to keep re-humidifying it. An OAK would mean you "burn" outside air, which would reduce that problem. Other than that issue, there probably isn't that big a difference between wood heat and any other, besides the fact that you might have more fluctuations - I'd be more worried about temperature changes than humidity.
Gooserider
