First you need to determine if a lack of power (most probably), or a lack of chutch holding ability (not likely) is your issue. When the chain grabs and stops moving, what does the engine do?
(If the chain was too agressive it could take too big a bite for the engine size, but from the looks of the pics you posted on the chain, it doesn't look like this is your issue.)
If the engine just doesn't have enough power that's one thing, but that could just be because of the state of tune. Have you tried adjusting the carburetor? The high speed needle could be off and therefore severely limiting power.
What happens if you throttle up fully BEFORE beginning your cut? Does it bog down quickly and stall the chain (not the engine) as you begin to cut? Does it only stall the chain when you bear down into the cut? The chain should be sharpened properly so that you do not have to bear down when cutting, but it should allow just the weight of the saw itself to basically make the cut on it's own, with you only having to guide the saw.
I didn't see your cylinder pics, but if there is no severe scoring I doubt that this is the issue. Again I go back to the state of tune. I'd try some carb adjusting, and make sure fuel delivery is not a problem. Make sure the clunk in the tank, and the line to the carb are in good shape and are clear, and are not partially blocked nor pinched. If so, then try asdjusting the high speed needle to see if this gives you more power. If it behaves eratically to the adjustments the carb might need overhauling (due to fuel deposits or trash in the system). This could be causing issues with the carb diaphram also, which will definintely effect power output. If you've never done this before search around online and you will find overhaul info and some good step-by-step guides to help you through it. Just get your carb model number and brand, and you'll find everything you need.
From the looks of it your clutch did get hot (blue coloration indicates overheating - due to slipping) but that is most probably due to the slippage incurred from when the chain stalls and you continue to feed it fuel while the chain is still stalled. Again, my guess is that the issue all boils down to lack of power due to an inadequate state of tune. I'd try to wake it up first by starting with the carb and the fuel delivery system. Heck, I've found brandy-spankin-new Walbro and Zama carbs (complete!) for my 31cc weed whacker engines on ebay for less than $10.00!
Good luck!
Good luck!
I got tired of pulling the starter rope so much.
