The Pferd sharpener arrived yesterday, and files should arrive tomorrow, and then I’ll get to work! I might do a few cuts with the saw today (even though it’s not sharpened yet) just to have a clearer sense of before and after.
I’ve been using a Stihl/Pferd 2 in 1 sharpener for the past few years. I borrowed my uncles for a while and last year got my own.You'd do well to learn to sharpen standard chains with standard methods. A hand file and guide is a good way to go, for most firewood cutters.
yep, I was counting the 2-in-1 among the "standard techniques", as opposed to those gimmics that automatically sharpen special chain on the bar. Heck, I use a bench-mounted grinder, another "standard technique" applied to "standard chain". Point is, understanding the criticality of three angles and a depth gauge height.I’ve been using a Stihl/Pferd 2 in 1 sharpener for the past few years. I borrowed my uncles for a while and last year got my own.
Before that I used a round file free hand, and a flat file to touch up the depth gauges. I’m much more consistent with the Pferd sharpener.
Once you get a bar mounted file jig or accurate bench mounted grinder you will have chains sharper than new.I've used the Pferd 2 in 1 the last few sharpening. Works better than what I could do free hand or with the HF sharpener. Actually, Seems to get as good results as a new chain.
I have a trailer hitch mounted rig with a small vise. It's not perfect and there is a bit of slop, but it worked good enough to keep a saw in one place while I used a bar mounted file and later grinder (both Granberg). You could probably figure out how to get the slop out of the hitch setup, it was just never enough of an issue for me to deal with it. If I remember today I'll take a picture of the rig. I don't have a shop/shed/anything to do work in right now, so most of my stuff lives outside, like my portable vise rig. It's all chinese stuff from amazon, didn't cost me much and still works after living outside for two years. The screw on the vise is rusty, but functional with a bit of effort. If I were smarter I would have sprayed it down with chain wax.I sharpened my chain this weekend! As mentioned earlier, I got the Pferd CS-X (2-in-1), and some of the Pferd 11/64" files needed for my chain.
A few observations / comments:
- It took a bit more work than expected / hoped to put the 11/64" (4.5 mm) files into the sharpener, which came with 5/32" (4 mm) files. The holes weren't quite big enough. But, following the principle that you don't really own it if you can't modify it, I took a drill and gently enlarged those holes until I could fit the larger files. It was a little awkward because it's hard to get a straight shot at the holes (especially at the end that doesn't open), but I made it work, and it's a one-time modification I won't have to do again. If I get a different chain in the future and want to put the larger files back in, I can just put a bit of tape on their ends.
- It was a little tough to get the first pass started on each tooth. I don't know if that's just because the chain was dull (burrs?), or if the factory angle was just slightly different than the Pferd sharpener uses. (I did double-check that the files looked straight [parallel to the flat file and the guides] inside the holder after my modification.) But once I got the first pass started, then subsequent passes were easy.
- It took a little practice to get a smooth flow with sharpening one tooth, flipping the file, and going the other way on the next tooth. But not hard once you get the hang of it, and the markings on the handles are helpful.
Overall, it seemed to work well - the saw definitely performs better than before. Easier cutting, larger chips.
My other observation: I need a vise! I jerry-rigged an arrangement with some clamps to hold the bar, but it was awkward to set up. I could get a stump vise, but I think I'd be better off with a real vise, maybe mounted on a board. (I don't have room for a real workbench, so I just use a foldable Workmate.) Any recommendations for vises would be welcome. I might just try to pick up a used older one.
Thanks for all of the help and advice in this thread!
Vise is Key to hand sharpening. Holds saw rock solid. So much easier, faster, and accurate filing than without.I sharpened my chain this weekend! As mentioned earlier, I got the Pferd CS-X (2-in-1), and some of the Pferd 11/64" files needed for my chain.
Many folks who hand file report finding it best to do it after each 2nd tank of gas thru the saw. This seems to be an ideal compromise between time lost setting up to sharpen, and time spent sharpening.I sharpened my chain this weekend! As mentioned earlier, I got the Pferd CS-X (2-in-1), and some of the Pferd 11/64" files needed for my chain.
Or when you just get dust and not chips ...Many folks who hand file report finding it best to do it after each 2nd tank of gas thru the saw. This seems to be an ideal compromise between time lost setting up to sharpen, and time spent sharpening.
I just can't hold it dead steady if not in the vise and i use 2 hands on the file anyway, so i would have to do the lie down on the saw move. Vise just way easier for me.I almost always hand file without a vice. It does not take much to hold the saw in place with the hand that's not holding the file (which I use to hold the chain in place on the bar). You don't need to push the file hard into the tooth, moderate pressure is enough.
When filing it can be useful to examine the underside of the teeth to see if you are filing the underside of the tooth. Also inspect the top of the teeth. You need to file enough so the hard chrome layer on top extends all the way to the cutting edge.
That's when it's time to buy a bench grinder!Or when you just get dust and not chips ...![]()
