Which Manufacturer for Class A HT Chimney?
MrKenmore
66
I need to change my existing HT chimney from 8 inch to 6 inch come the spring. Which manufacturer should I go with? Metalbestos, Duravent, Metal Fab? Is any better than the other? Thanks!!!!
They are all good and meet the same standard. You should check to see which is available locally with all parts - don't special order, if possible. Usually I would suggest checking the OD of pipe and what size framing it will fit through, but since you are replacing a larger with a smaller you should not have that problem.
