Which chainsaw to buy- stihl ms180 v ms250?
There's a Mastermind ported 261 on CL here for like $650 with 5 tanks thru it. If money was no issue for me...
Sorry, $600
(broken link removed to http://lancaster.craigslist.org/for/5266252287.html)
I have a 180 and really like it. The light weight, tool less bar, and overall performance makes it a great little saw. I use it mostly for limbing, but it will handle some 10" oak pretty good with a sharp chain.
If I had to pick only one saw though..it would be a larger one.
Jazzberry ( or anyone who can answer ) you have piqued my interest in this 026/024 saw. For the 026 specifically, I see them on CL, some have the PRO emblem some don't but it looks like they all have the decomp button. How do I know without physically holding it whether it's a PRO and worthwhile maybe driving to see it? And conversely how to spot a non-pro saw. Not that I "need" another saw, but with the CAD.... Thanks!
Only the Pro models of 026 and MS260 actually have (or had when new, anyhow) a decomp, but the base model MS260 uses the same orange engine shroud as the Pro model, with a black filler piece blocking the decomp opening. It's hard to tell the difference in a typical low-res Craigslist photo. The original shroud on the base-model 026's would not have a decomp hole, but some people refurbing an 026 will replace the OEM shroud and air filter cover with aftermarket MS260 plastics, which again will have a decomp hole whether it's needed or not.
If the saw you're looking at has screw caps, then it's an 026. If it has flippy caps then it's either a late-model 026 or an MS260. 026 plastics are flatter across the top, while MS260 plastics have a hump running down the middle. If a saw has screw caps but the engine shroud and air filter cover are humped on top, then it's an 026 wearing 260 plastic, probably aftermarket. If it has a screw-type oil cap and a flippy gas cap then it's an 026 with a 260 gas tank/rear handle assembly. The easy compatibility, the popularity of the models and the vigorous aftermarket for parts means these things get mixed and matched a lot.
The other differences between pro and non-pro are even less likely to be visible in small pictures, but if you go to see a saw then an adjustable oiler is a good pro feature to look for.
You're welcome. For the record, the only "pro" feature I really care about on these is the adjustable oiler -- not because it's adjustable, but because the adjustable oiler is clutch-driven and only moves oil when the clutch is engaged. The non-adjustable oiler pumps even at idle, which gets messy and wasteful in some cutting situations. I have an early non-pro 026 that I love in most respects. A decomp would be nice, I suppose, but it runs so well as it is that I'm not about to switch cylinders. I am, however, gathering parts to swap in an adjustable oiler.
Reactions: D8Chumley
I don't care about the decomp either, I'm still able to start a saw without using it. Adjustable oiler is a nice feature however
Here's my base-model 026, just after I put it back together. It's stock except that I improvised a thinner base gasket to adjust the squish.
Nice Jon. Thats why most pros keep an 026 around. Along with the power they are very light and agile.
Reactions: Jon1270
