Hello,
I've read several threads here in the boiler room but can't decide on what to do.
I'd really appreciate a few idea's or recommendations. a few years ago we planned on an OWB but plans were put on hold and I'm starting almost from scratch.
My heat load is approx. 45,000 btu at -30c and we just finished more than 30 days straight of those temps so that's a pretty accurate #. Coldest February on record. I have in floor radiant heated electrically in the basement concrete floor and in floor radiant on the main floor which is half wood floor and half tile, the open loft is currently heated from the main floor wood fireplace.
New system is planned as follows:
radiant in floor basement 900 sq ft
radiant in floor main floor 900 sq ft
radiant in floor loft 160 sq ft
3 small radiators in loft 300 sq ft
Garage in floor radiant 1000 sq ft
water will be heated by a wood fired boiler (brand TBD) with an electric boiler back-up (BTH Ultra). Garage will have a wood stove inside, back-up to the radiant when I'm working in the garage. I have lots of scrap wood.
Our living situation is that we are away from the house during the week for 10 hours each day and would prefer not to use the electric boiler therefore the wood fired boiler would have to provide enough heat. not sure if that is in the form of a long burn or water storage. Oh, the boiler will be outside (not negotiable), storage could be inside or outside. however I prefer not to install storage unless it makes perfect sense.
My only questions are:
would you recommend a gasification type boiler? or regular OWB
I'm looking at an Orlanski 200 model 60 (EKO 60) are they the exact same boilers? Orlanski vs EKO
If I went with the EKO 60 instead of the 40 (bigger firebox) will I be wasting wood with idling, or is that an issue I have to deal with because I need 10 hours?
Is going with a 60 instead of a 40 the difference between storage or no storage?
I'm using the EKO as an example but open to any reasonably priced boilers. Also, my cost for firewood is very low so it's not a reason to sway me one way or another unless it doubles my wood consumption.
I burn 10 face cord of red maple each year. the fire is lit in early Dec. and burns until late March. with small fires outside that time frame.
I appreciate any advice anyone can provide. I spoke (email) briefly with No Fossil and I plan on using a Vesta which should help with efficiency.
Thank you.
Thank you.
