Cearbhaill said:Both baking soda and baking powder have been mentioned in this thread.
Once and for all- which is it?
And how much?
I am certain that it has always been baking soda recommended to me in the past, but three times here I have read baking powder.
This needs to be clarified and put in a sticky or FAQ.
IMO
Kilted said:Instant off should be easy, just use CO2 fire extinguisher directed at the air intake. That should smother the flame very quick. However the draft will pull fresh air back into the box with unperdictable results.
OK other suggestions on further blocking the air intakes?
johnsopi said:In would think a bucket of water to be a bad idea. Thermal shock to the steel stove, burns from steam ect. Sand or ash or fire exstinger
Shari said:Brian VT said:EPA approved stoves cannot, by design, allow complete closure of all air intake. Some people have devised ways around it.
The culprit is usually the secondary air intake.
After reading many posts on this website, I agree your statement seems to be true, however, as a future stove owner I also find this issue to be very disconcerting on so many levels! While EPA stoves are the current trend how in the world did the EPA approve something that can act like a runaway locomotive with no way to stop it??? While I also understand people with a 'runaway' can sometimes cool off their stove by shutting down the air and blowing a fan across the face of their stove to cool it off, to me this is not a good design. I am no rocket scientist but I do want control. I want a stove for all the benefits it can offer but "I" also want to control it - what is the solution????
I realize my fireplace is a hole-in-the-wall heat loss, but at least if I want to shut my fireplace down I can do so just by closing the glass doors and closing off the air intake. Why can't I find a stove that I can shut down if need be?
Shari
Shari
Around here all the really old homestead houses had a permanent ladder on the roof to the chimney. Likely to facilitate cleaning but also for a quick response in case of a fire.oconnor said:...figure out how to address the issue from the roof, and prepare for that.
mayhem said:glenng said:While the results of putting out a wood stove fire with water can be disastrous, I have found a quick way to kill an over fire. Continuously spray a mist of water from a quality spray bottle on to the fire. 30 seconds to 1 minute of spraying will bring a raging fire to idle. I keep a spray bottle handy. I learned the trick from an old timer and it works. I had to use this method once and it worked quickly and safely. This method works for a fire in the stove. This method will not work for a chimney fire.
Do you open the stove and spray directly on the fire or do you spray the water into the air intake?
sonnyinbc said:Do you put the pedal to the metal with a brand new car?
Learn how to operate your new stove/insert. And no such thing as a runaway fire.
I will say dry seasoned wood, and will repeat--dry seasoned wood. burn it till the secondaries kick in and gradually turn it down, not rocket science we are talking about.
A year ago at this time I too was worried about the lack of control,,, not anymore. This new technology beats the ass off the old stuff.
Only exception I can think of is the downdraft burners. Looks like a bit more of a learning curve, and even then, maybe not work quite right.
But that is why you are on this forum, right? to learn how to operate your new appliance properly?
glenng said:sonnyinbc said:Do you put the pedal to the metal with a brand new car?
Dont be a schmuck. Everyone started out as a newbie myself included. When a new wood stove owner gets their 1st stove there are going to be questions. Are you here to prove how great you are at operating your wood stove? I am here to share the knowledge that I have learned and to pass it on. I haven't figured it all out so when I do have a question I want it answered with empathy not with ego.
Glenn Gertz
Glenn Gertz
