I don't know if this has been mentioned before Goose(this is a long thread). Would a bead cushin help? Seems like it would make it much easier to shift from time to time. They make these with different size beads, Randy
Singed Eyebrows said:I don't know if this has been mentioned before Goose(this is a long thread). Would a bead cushin help? Seems like it would make it much easier to shift from time to time. They make these with different size beads, Randy
Slow1 said:Seem to me that one could go broke pretty quick trying all these different 'technologies' eh? Wonder how many of them have a "try it for 6 months - return for any reason if you don't want to keep it for full refund" policy...
wendell said:Have you tried a gel bed? I have gone through every type of matress imaginable exceot a Duxiana over the past 15 years and finally bought a gel bed a few months ago and am pretty happy with it (at least more than any of the other beds I have tried.
Gooserider said:Thanks for the post SZ, I've heard a lot of references to the MIT bike but this is the first time I've seen such a detailed writeup on it... A couple of potential issues that I see with it though, could cause problems...
1. Most people get their chairs via insurance - I don't know how the insurance companies would react to paying above "standard chair" prices to fund their buy/build model, but I suspect they'd be a problem...
Maybe a partial payment??
2. More significantly I see that sticking out front wheel as a real potential problem for indoor use... Part of my biggest issues with getting around in the house involves the size of my chair - I need at least the width of the chair, and then have to worry about being able to turn around, which is heavily influenced by the length of the chair - currently my manual chair isn't much longer than my seated leg length, plus another foot or so for the wheels in back... It basically isn't possible to build a chair much shorter as the rear push wheels basically need to be under the center of your butt in order to keep from going over backwards (my chair is set up for minor "performance" so it is relatively easy to wheelie, and I HAVE managed to flip over backwards - NOT FUN!) As it is, many of the places I go in the house are "one-way" in that I can't spin around, and some also have tight right hand corners - I'm not at all sure I could get into places like my bedroom with that long front end, as I don't know if it could make the corner...
There are a pretty sizable number of off-road designed wheelchairs that use a similar style drive system, and all seem to have the problem of being to big for use as a primary indoor chair... One of the issues is the drive system - part of the game in wheelchair design is to keep the overall width as narrow as possible, as every fraction of an inch means more doors that can be gotten through, and other similar accessibility concerns. My manual chair is sized to be just barely wide enough for my butt when I'm dressed, plus maybe an inch to allow for pressure relief movements. I then have my clothing guards, and maybe 1/2 - 3/4" between those and the inside edge of the wheels... I don't think there is any way they'd have ROOM to put the drive system in without making the chair wider - even the bicycle hubs mentioned are wider than the standard chair wheel. As an example of how extreme this can be, Spinergy, which is a company that specializes in high end performance wheels for chairs and pedal bikes, has a system where they mount the push rims with a flexible rubber bond, so that they can be squeezed in to get an extra 1-2" in order to get through a door... I can't justify them, as we were able to get enough room for me to get through the first floor of the house by removing ALL the doors... When we redid the bathroom, that door was replaced by the accessible sized 36" wide door, and once I get through putting poly on it, we will probably mount it, but not use it all that much as it will still be a pain to open and close... Because of the way the hall is laid out, I don't think we could redo the bedroom doors for more width, but I can deal with them as long as the doors are removed. We might try those fully opening hinges, but it's a pretty low priority.
Gooserider
szmaine said:A quick comment or two...
I can't imagine how frustrating all this must be for you.....You are obviously a very strong person dealing with all that and kicking the painkiller patch too.
Strong... and a critical thinker....
Maybe you are up for a project??? You're in Billerica?? - from Worcester County myself.
From the article I posted..
"As for the second track, the LFC Sport, is currently in the prototyping stage. The Mobility Lab is already going out to wheelchair users in the Boston region to determine the interest in the idea"
Seems to me you might have alot of valuable feedback for such a project, just a thought...
I don't know if they are having people test the protypes or what but maybe it would get you in on one. Some guy collect cars...
The website...
(broken link removed to http://mlab.mit.edu/lfc/Chair.html)
The email...
mlab-web@mit.edu
Cheers Suzanne
ps. what about some kind of widow shade instead of doors...
