I shovel ash when stove is cold. Spread the ash in winter in my raised beds for the spring/summer veggies. Big difference in my crops last year. Great article on doing this years back in The Old Farmer’s Almanac.
I have found that, with this newfangled high efficiency stove, if I let ash build up in the firebox the heating efficiency plummets. I can only guess at the reduced efficiency numbers but I would estimate the heating power of the stove drops to about 20%! Yeah, I'm not joking...80% drop!I don't clean ashes out the stove more than once every two or three weeks. The frequency obviously depends on the size of the stove, how much wood you are burning, and what species, so your results may be very different.
Sounds like they may have cut some corners for the air intake. A full ashpan shouldn't affect the fire, but apparently in this case it does.The amount of ash in the firebox certainly affects burn times. Having a couple fire's worth of ash will increase the burn times and not negatively affect the heat output. But more than 24 hrs worth of continuous burn creates a very difficult situation to manage in my Panadero. All that said, having a lot of ash in the firebox can help keep the heat output down if the user needs output. In my case, I find it a waste of wood and would rather adjust the air intake which gives better control IME.
Again, I do NOT love this stove, it's been a frustrating learning curve and takes far too much continuous attention from the user.
Ash pan on the Mansfield is so small. I empty it one time. At the end of the season.Sounds like they may have cut some corners for the air intake. A full ashpan shouldn't affect the fire, but apparently in this case it does.
a full ashpan absolutely does affect air intake on the Délice/ Dover...I tried it today after posting...Sounds like they may have cut some corners for the air intake. A full ashpan shouldn't affect the fire, but apparently in this case it does.
for one year maybe 🙄It doesn't sound like a stove designed for 24/7 heating.
That says it all right there.In order to achieve the stated nominal heat output of this stove a total quantity of 2.5kg of wood (roughly two logs weighing a little over 1 kg each) must be placed inside at intervals of one hour.
In a firebox 3 times the size of the 602.Heck, the Jotul F602 V2 states max burn times of 5 hrs! and @begreen you say you get 14 sometimes
They are cute little guys aren't they. I ordered one for our new stove since I loved the on on our Dutch West stove when burning 24/7. I took the shaker grate out and it's at least a little useful now.Ash pan on the Mansfield is so small. I empty it one time. At the end of the season.
it does...stove was already purchased by that point...there was no time and no stock...monthly elec would have cost more than the stove...we're doing our bestThat says it all right there.
From the Dover manual:
"The stove is intended to function intermitently with intervals for recharging the fuel.
- For the lighting process of the stove it is recommended you use paper, fire lighters or
small sticks of wood. Once the fire starts to burn, add to it two logs of wood each weighing 2 to 2.5 kg as a first initial charge. In this lighting process the air inlets of the stove must be kept completely open. If necessary the drawer for removing ashes can also be opened to begin with. Once the fire is more intense, close the drawer completely (if open) and regulate the intensity of the fire by closing and opening the air inlets.
- In order to achieve the stated nominal heat output of this stove a total quantity of 2.5kg of wood (roughly two logs weighing a little over 1 kg each) must be placed inside at intervals of one hour. The logs should be positioned horizontally and separate from one another, to assure a correct combustion. In any instance a charge of fuel must not be added to the stove until the previous charge has been burnt, leaving only a basic fire bed which is enough to light the next charge but no stronger.
- To achieve a slow combustion you should regulate the fire with the air draughts, which must be kept permanently unblocked to allow the combustion air to be distributed."
pretty much impossible to keep a fire going with splits not touching each other! So, splits have to be added once every hour? Then how can they advertize 5-12 hr burn times! I doubt I have much wood at 20%...certainly my wood vendor doesn't deliver 20%...I gotta dry my wood stocks to burn his product...and I'm not alone
so yeah, your milage may vary...not all products are built alike
we do what we can with what we've got![]()
I need something better, for sure...that said, isn't better to help others by sharing experiences? That's what these kinds of forums are for I reckon
see, I think this is all worth discussing...hence why I registered here...maybe my experiences can help others who jumped on board with these newfangled EcoDesign stoves...took advice from a big box store and even the manufacturer doesn't know how to communicate with their customers...but obviously should have its own thread so I will carry on in another thread rather than continue to derail this subjectit does...stove was already purchased by that point...there was no time and no stock...monthly elec would have cost more than the stove...we're doing our best![]()
still, when I followed those instructions, the firebox deformed
salesman at the store said this rolled steel build was as good as cast...he was incorrect...it's ok...we aren't freezing or going broker paying elec
just not gettin a lot of sleep
I did the same thing except they were in the bucket for 3 days. Next thing I know my woods where on fire luckily I saw it before got to big used a fire extinguisher to put it out.Someone burned down their house by doing that a couple of years ago. Leaves caught fire late at night and that spread to the house. Wait longer. Hot coals buried in ash can stay red hot for many days.
I don't think the issues have anything to do with it being an ecodesign stove. By the description this is a room heater, designed for short fires. More like nights and evenings, with a big fire view glass, at a low price. It is what it is..maybe my experiences can help others who jumped on board with these newfangled EcoDesign stoves...
again, not according the rep at Castorama who sold the "appliance"I don't think the issues have anything to do with it being an ecodesign stove. By the description this is a room heater, designed for short fires. More like nights and evenings, with a big fire view glass, at a low price. It is what it is.
It's as much the fault of the flue system as the small capacity stove. The long horizontal section right off the stove makes for a sluggish start. Once the tall exterior chimney gets cold, it takes a fair amount of heat get draft established again.Further, one thing I haven’t made clear is why I run my Panadero Delice 24/7…the main reason is how difficult it is to cold start…it’s far easier for me to keep it burning 24/7
indeed, thanks for the clarificationIt's as much the fault of the flue system as the small capacity stove. The long horizontal section right off the stove makes for a sluggish start. Once the tall exterior chimney gets cold, it takes a fair amount of heat get draft established again.
