What's your longest burn?
Usually 8-10 hours of heat from the Mansfield, I have gotten 12. Burning a walnut and ash mix, mulberry on deck
Thanks HighBeam. Something to consider. When you say 30 hours, what temp average do you see on the stove, and up to what point do you get these temps. and Yes, most things are higher in price in NY. thanks.
I also have a 17vl and so far my best burn time has been right at 4 1/2 hrs on a full load of oak. I've been burning the heck out of this little stove this year and I'm very impressed with it. Average burn times are probably 3 hrs give or take.
When you're burning for 24-30 hours at a stretch, stove temps are not nearly as important. The stove's duty with a long burn is to keep the house warm not to impress with eyeball searing heat. For the bulk of a long burn, internal flue temps run between 400-500 and stove top temps also from 400-500, after about 20 hours both of these temps drop down to 300 or so. It may not sound hot but this is constant heat and not the pulse and glide cycles of a non-cat. I've burned both and much prefer a tortoise approach and not the hare.
Amen well said.
Lopi Declaration 2.9 cu.ft. firebox insert. I've got consistent 6 - 8 hrs of productive heat and can relight from coal till 10 - 12 hrs. Today is special that I've just relighted from small amount of coal @ 5:00pm from 10:00pm load last night.
With the Castine, I get about 6hrs of real heat; will have coals left for relight for 8 maybe 9 hrs tops.
Exaggerations welcome.
Well if exaggerations are welcome and we can say coals to relight without a match, 28 hours on a load of black locust. 20+ hours a few times. Now, real world anything I might be able to call any heat, say maybe 200* 16-18 hours. Realistically needing enough heat that the stove should actually be burning and it has perfectly clean glass, 10-14 hours to about 300 on a full load.
Thanks Highbeam, this is very helpful. and yes i agree that constant 300 to 400 radiated heat will keep the house warm. thanks, we are hoping to replace our 30 next fall.
ALRIGHT!!
No CAT Stoves.......need a new thread for us non-cat lamentors........
That's the way to do it. Specify wood stove and non-cat only. May as well ask for a corresponding firebox volume.
I quit my job as a stove babysitter in March 2011 when I went with a BKK.
My next unit could be a cat stove - I would not be unhappy if a BK sat on my hearth, love the cat reviews, etc. - and the back hurts a bit more every year, and all that. - but I kinda like babysitting the stove right now. Sort of the fire bug in me, I suppose...?
26 hours in my old Jotul cat stove. Stove top temp held around 300F thru burn and cat held above 500F for most of the burn. I think I have my not-properly-seasoned wood to thank.
I have a Pre-EPA Blaze King King. I've never attempted it but I suspect I could get around 36 hours on a full load of hedge and still get a *relatively* clean burn.
I can get 24 no problem with average wood and fans off...and 18 no problem on a full load of hedge and fans on high. I only regulate the heat output with the fan speed. I run it hot or not at all to keep the creosote to a minimum.
Shoulder weather we have done a little over 36 hours with our Blaze King Princess Ultra. Usually with heavy heating over night we do 12 -14 hours.
