Building 1200 sq ft with 19X39 great room with 15ft vaulted ceiling. Looking at Dutch West catalytic. Should I go small which heats up to 1400 sq ft or large which heats up to 1600 sq ft?
Welcome, in Texas isn't it mandatory to go big? lol
I would go for the large. Burn shorter, hot fires if the weather is mild and let the fire go out. The space may only be 1200 sq ft, but the cu ftg with the cathedral ceiling almost doubles the sq ftg in that room. Be sure to have reversible ceiling fans installed in the great room to break up the heat that will stratify at the peak of the ceiling.
We usually recommend to not look at the advertised sqft ratings of the stoves as they can vary greatly with winter temps, insulation levels, wood species burned, floor layout etc. The size of the firebox is often a better indicator of how much a stove can heat since more wood in the stove will mean more heat. You will probably be ok with a stove in the 2 cu ft range assuming your winter temps are rather moderate. A catalytic stove may be a good idea because you will be able to regulate the heat output more easily and won't heat you out of the house when it is not that cold outside. Have you looked at other brands such as BlazeKing or Woodstock?
In addition, do you have dry, seasoned wood already? Any modern wood stove will need wood with a moisture content of less than 20 % and it is often hard to find a firewood seller who has that. Hence, most of us here dry their own wood for 2 to 3 years in our yards.
There is little to choose from where I live. So. I haven't looked any further than what is available locally. I burn seasoned pecan and mesquite that I cut and let dry for 2 seasons. I'm 200 miles from Austin and San Antonio so I may be k to see if any dealers carry the above mentioned brands. Thanks for your insight.
