Yes, that's about the same situation/conditions as me. We live in the part of WI called the Central Sands, it's all pure sand and I live on high ground. My bigger piles have also been stacked in the same place for many years, so have a layer of bark, wood chips, etc. under them. But that's right, all of the wood isn't touching the ground like some of the worry-warts would seem to imply, only the bottom (sacrificial) layer. Everything above the bottom is elevated, just like everybody else.Backwoods Savage said:Elevating off the ground indeed is good and I doubt anyone would argue with it. However, there is some of our wood that is stacked directly on the ground and we've done this for years. The reason it works is where we stack. It is on high ground and nothing but sand. Water goes through sand like **** through a tin horn.
The only bad thing we find is that some of the wood will bury itself right into the ground but that is no problem. In the spring, we then tap them with a maul and they pop right out. Those are then thrown on top of another stack to be burned later. Reason? They aren't seasoned! But it is just the bottom layer and not all of it. Some can be burned right then. And if you've seen any of my posts, I probably have close to the amount of wood that quads has. At last count it was 23 cords.
23 cord is a good bunch of wood. I've never precisely measured all of mine, but I would say there's that much or more at any given time.
		 if it's wood and drys out I will burn it.
 if it's wood and drys out I will burn it.![[Hearth.com] What seasoned wood looks like to me.](/talk/data/attachments/19/19967-c9b67412bd1f9b18e5e85fce636dd2eb.jpg?hash=evHYp7yonb)
			![[Hearth.com] What seasoned wood looks like to me.](/talk/data/attachments/19/19968-13d8093046bbeba6c430c6bf0d620916.jpg?hash=pGLB17-ndz)
			![[Hearth.com] What seasoned wood looks like to me.](/talk/data/attachments/19/19969-fd77453a23723fe73d5921314f14c9e3.jpg?hash=kW38RbhJl4)
			![[Hearth.com] What seasoned wood looks like to me.](/talk/data/attachments/19/19970-15ed3fc31574fb89fc2f4b2b24950f49.jpg?hash=_bbWGttqKg)
