Just noticed these replacement LED bulbs for T8 fixture but not all that much cheaper than the whole light. And only 30 watts total.
(broken link removed)
That's encouraging. I was assuming I would be retrofitting my T12 fixtures, but I may end up replacing them altogether when the time comes. We'll see.I get the 4 foot LED shoplight available in a 2 set pak. For $32.50 Unit, Nice and bright at 4500 Lumens
Price has been dropping steadily
ID rather go with the whole LED fixture. That way i know the the bulbs are matched correctly with any other components of the fixture. ,and they do claim 50000 hour bulb life.Theres no way im getting anywhere close to that out of my remaining T8 bulbs and fixtures
A friend put a full set of T8's in his wood shop. Good light, but they completely block radio reception. Thinking now of taking them out and putting in LEDs.
I have about 4 T8 fixtures all purchased in the last 12 months in 2 different locations. Every single bulb in every fixture has about 2" of black on each end. They are going downhill way faster than my old shoplights. No way ill ever see anywhere near 30000 hours ,ill be lucky to get a few hundred hours.Yeah, 30,000 claimed from the 2$ t8 tubes. That's like 30 years at 3 hours per day.
Some ballasts are harder on tubes than others depending on the start mode and output (normal vs HO).
![[Hearth.com] What lighting do you recommend for an often cold garage? [Hearth.com] What lighting do you recommend for an often cold garage?](https://www.hearth.com/talk/data/attachments/178/178826-c205eddcc4a189df20d4af5f0c79e679.jpg?hash=a2AKKLWfum)
I'm finding that out, but I'm hoping to find LED T12 tubes that will work with the ballasts bypassed. At least I'm okay for now, and the cold garage is only a concern when it gets cold again. Too bad. I actually like the T12 fixtures. I'll figure out something. Maybe the LED fixtures will improve with time, as I would expect with such a young and ever-changing technology.I don't think you'll find quite as many T12 compatible LED tubes as T8 LED tubes, and few seem to specify that they work with magnetic ballasts, so I suspect you'll find yourself replacing the fixtures instead of just the tubes.
Doesn't lumen output pretty much depend on color? I wonder what color name emits the most light?Check the lumen output as well ,the LED shop lights sams club offers for $35 list 4500 The Home Depot LED shop light For $39 lists 3200.
Often higher color temp LEDs bulbs will have a bit higher lumen output, at least for 12v bulbs.
Yeah, that's what I was getting at. The "warmer" , lower Kelvin equivalent colors always seem to me to be less bright, but I haven't looked at the numbers much to see it was just perception, or a matter of fluorescent material used.Often higher color temp LEDs bulbs will have a bit higher lumen output, at least for 12v bulbs.
