JP11
Ok.. could be a dumb statement..
but could the fan be wired for 220?
You've got half the "legs" of power and half the fan speed?
Note.. I did NOT stay at a holiday inn express last night. I'm sitting in bed at a doubletree!
 so I took it to my favorite machine shop and they welded on a short piece to the end of the shaft and machined it true, you'd never know the difference looking at it now.  The fan was hitting the motor plate, no way around it, someone must have been sleeping on the assembly line.  This mod to the shaft in no way has any bearing on CFM befor or after, just mechanical room.  Anyhow, everything on that end is good as far as I know.  Fan works well, pulls smoke into the lower chamber easily and is very easy to start a fire, with quick rumbeling noises from the lower chamber.  After the door is shut though, I don't know what is going on.  Can't peek at the secondary flame, and it's very quiet outside the unit other than the fan noise, no rumbeling.  I have no baseline so I don't know what is normal.  I want a window to see into the lower chamber during a burn, than the truth will be out!  Should have bought a Varm, as it was my first choice........
  This thing puts out some heat, charger my 115gal indirect from 105 to 175 and had to dump quite a bit of heat in the floor.  The reason I fired it was to charge the indirect so I didn't need to fire the toyotomi for a shower in the morning.  Anyhow, things are looking up, I was thinking the fire needed more air, it is always my motto to let more air in if the stack is low, but not this time.  I still think my stack is low, but it burned well, and some of the tar-glazeing in the lower chaimber exaporated/burned off.  Thanks all for your input!  Buyers remorse now gone
  Now that I have some type of baseline, I can work from here.
 , but even with good gassification I am seeing stack temps around 400. The Boxelder is certainly not a premo wood, but with it being free, I am going to continue to take it when I can get it! The stuff I am burning now I split almost a year ago and put it under the porch way too early. Luckily I put it in the back and left it there when I realized this spring that it was not ready to burn. M.C. was still too high. But it has been great to burn the last four weeks for hot water and a very small amount of heat demand every once and a while.
