I have read many times in different authoritative sources that boilers must be protected from return temperatures below 130F. Around this forum 140F is often stated as a safe minimum for wood boilers. Yet it seems most of the Termovar or Danfoss valves used for return protection by people on this forum are rated to open at something more like 160F. That is what Tarm used to supply with their boilers.
These thermostatic valves are made in models that open at 140F (or lower, for other uses I assume). So why aren't they more common? Seems to me the cooler the return temp the easier you can extract the heat from the boiler. And at lower pump speeds and less pump electricity.
Are there reasons that in real-world practice make it better to return water warmer than 140F? The only guess I can make is that it's safer for the many installations without heat storage that idle a lot.
If you have lots of storage and never idle under normal conditions wouldn't a 140F return be more efficient?
Any of you out there using 140F (55C) returns? Do you have storage? Problems with condensation or soot buildup in the firetubes?
I wouldn't expect it to make enough difference to make it worth the expense to swap out an existing setup but for an initial installation why not use the lower temp?
