Let me ramble a bit for the guys who, like me, aren't ashamed to twist a wrench but haven't spent any time inside a chainsaw, not yet anyway. This is about the oil pump that is responsible for lubrication of the guidebar and chain.
One of my saws wasn't oiling. Its a Stihl MS361. I checked the oiling in the normal way; I removed the bar and chain and then started the saw. Running it at moderate speed for several seconds I watched to oil port to see if any oil came out. I did this when I first bought the saw (used) two weeks ago and it was oiling fine then, so I had a reference. When I checked it yesterday it wasn't oiling. I have to tell you that between the two tests the clutch bearing failed and was replaced - more on that in a moment.
So, there I was with a saw that wasn't oiling and me not knowing much about how saws oil.
First lets back up to the clutch bearing. This is important because on my (Stihl) saw the clutch drives the pump. Somehow or another I managed to lose the clip that holds the clutch and rim sprocket together and on the crankshaft end. The saw kept on cutting and my son didn't recognize the odd sound it was making as anything unusual. The clutch wiggled around and ate the bearing and also touched the oil pump and wore a hold in its case causing it to malfunction. Of course I didn't know that at first.
I repaired the clutch and put the saw back together but it wasn't oiling. That's when the learning experience began. Apart it came. I thought I'd simply explain what is down there, how it works and what to do if yours fails. Its really very simple once you see it all apart.
OK, here is how it works. The drum part of the clutch has a slot in its edge. The oil pump is driven by a heavy wire that engages that slot. So when the clutch spins the oil pump drive, which is under the clutch, spins too. So that's the first thing, make sure that the little tab of wire is engaged in the clutch.
The pump itself is under the clutch. To remove the clutch devise a way to stop the engine from turning and then using a 19mm (3/4") wrench remove it by turning clockwise, its is a left-handed-thread. With it removed the oil pump is exposed. The drive wire attaches to a nylon ring that surrounds the crankshaft, lift it off. Under it the pump body is held in place by two screws. Remove them and the pump will lift up and off.
The first part I inspected was the drive gear. It is a spiral nylon ring gear with what looks like large screw threads. The threads on mine were undamaged and so the drive gear is good. The pump body exposes the pinion which is driven by the nylon drive gear. It is metal. Putting my finger on the metal gear I discovered it spun easily and smoothly, it too appeared to be good. It was at this time that I noticed the worn grove in the pump body on mine that exposed the end of the shaft on which the pinion gear rides. I did not know it at the time but that exposed part was right on top of the actual pumping mechinism.
Looking at the pump body I saw that the adjustment screw could be removed by taking out a pin,which I did. I then saw that the method by which flow rate is controled is by moving the initial position of the pinion gear, which moves ever so slightly in or out of the pump body, out increasing flow and in decreasing it. I then pulled the brass bushing out of the end of the pump and removed the pinion gear along with the saft/piston, washers (2) and spring that rode on it. It was then possible to see how the pump works.
Lubricant is held in the tank section of the saw and enters the pump through a hose that has a filter on the tank end. The end of the pre-formed hose acts as a bushing as the hose passes through the saw body and seals the inlet to the oil pump. When the pump is bolted in place its conical inlet is pressed into the rubber hose. So with the pump removed now is the time to clean the hose and filter and inspect if for cracks. On the suggestion received on another message board I cleaned the line with compressed air. Pfffssssttttt, all cleaned out.
Once the oil enters the pump it moves in a straight line fron inlet to the outlet with the pump's piston causing the flow from the center. The end of the piston has a cutout cavity about half the size of a drop of water. It is that spinning cavity pulsating in and out just a few thousandths of an inch, that pumps the oil. In effect it is a centrifugal pump with a power assist with the little jiggle provided by the eccentric on the end of the drive gear. The gear is held under tension by a single spring with a very small thrust washer on each end.
- - to be continued - -
