Okay. This is my first year with a wood burning stove. I installed a US Stove Country Hearth 2500 in mid-December. First fire was the 20th of December. Although I own ten acres of prime hardwood forest in the Midwest, since we began this year, I had to buy wood for this winter.
Since the 20th of December I have bought four ricks of wood from four different individuals all advertising “seasoned” wood.
We have heated the home 100% with wood since then; haven’t even turned on the furnace since then. Everything has been grand. Nights with temps below zero outside, able to keep all three floors above 70 inside.
Three days ago, however, I noticed a backdraft when I opened the door to the stove. It got so bad that I couldn’t open the door without the house smelling like a campfire. I read about the causes and decided that, despite my doubts, it must be a build up in my chimney. I headed to Lowes, bought a chimney sweep brush, and climbed the ladder to the roof.
This is what I found:
![What exactly is “seasoned” wood? What exactly is “seasoned” wood?](https://www.hearth.com/talk/data/attachments/223/223450-8a704d39984be153ba78be2ca9434800.jpg)
The inside of the chimney had about a quarter centimeter deep layer of fluffy powder-like creosote, but the chimney cap (especially the spark arrestor) had the bad stuff- dark, tarry, flakey, crispy creosote. There was so much that I could not see into the spark arrestor at all.
So, that answers that. The draft was definitely compromised, not because the inside of the chimney, but because the cap was encapsulated with creosote.
The question is: WTF is seasoned wood!!?!?!?!
Seriously!? Every bit of wood I put in the stove was purported to be “seasoned.” Yet, how was my stove able to create that much buildup in only two months?
I bought and used a moisture meter to test the wood, but there seems to be no consistency. For instance, if I pushed a little on some wood, I’d get a reading in the teens. Push a little more, and the reading is in the 20-30s. I have never once had a piece of wood that didn’t give me a reading of less than 30 when I really pushed the spikes in.
So, two questions:
1. Is this just what I should consider part and parcel of what it takes to heat with wood? I mean, should I just expect to scrape creosote 2-3 times a year?
2. What exactly is “seasoned?” When you say “at least one year” do you mean C/S/S in the spring, and burned the following winter (i.e., one full cycle of the seasons of the year), or do you mean C/S/S in the spring and left alone for more than 12 months, burning in year 2? I ask because I have been C/S/Sing wood every day for two months in anticipation of next winter. Should I not even bother, given that we are going to move a year from this spring? (Military family on orders)
Or am I simply the dope who bought crappy wood from four different people?
So, two questions:
