Hello guys I was interested in a Wood Burning stove last year after moving into a rural area in the woods but decided I could not afford it.
However after last years Propane bill I am wondering how I can afford not to.
I recently picked up a Jotul stove with all the piping and mounts that my brother traded for around $600 worth of labor from his company.
His guys packed it all up and are planning on installing it in my house this week, I agreed to pay him $800 and gave him $400 up front. I may end up paying him a couple hundred to install it.
It says Firelight CB on the back and I thought I had found it to be the Jotul Firelight f600CB model but after showing some people the Picture of the one I thought it was someone pointed out that it was a plainer version without some of the designs in the casting specifically at the front top corners.
Here is a close up of the front
Can anyone tell me if this is a f600 Firelight CB or some other model?
I was wanting to get the front screen for it to have the option open fires sometimes.
It came with no handle for the front and side doors so i will be trying to find those.
For now I can open them with a large allen key, I will need to identify the model and get a recommendation on where to find the parts.
I looked at the minimum distance to combustibles and the minimum distance from non combustible walls and picked this spot.
I would like to run the black stove pipe like this with another 45 to the fitting that goes through the wall to the chimmney.
Am I allowed to have it go back and forth like that?
I am also thinking I would use sheet metal or something to cover the joists above it to protect them from heat, this is in the basement near the outside door on the wall just to the left of the stove.
Here are the other pieces including the one that goes through the wall, the brackets to hold the chimney to the outside of the house and the piece of chimney that angles out around the gutter.
The front and side ashlips are there as well you just can't see them.
And Finally the Chimney
What do you guys think about what model this is and how and where I want to install it and Did i get a good deal ?
The mark on the wall for the hole is low mow that I added the 45 away from the wall to center the stove in the safe zone for the stove to burn before that wall turns to drywall and 2x4. (shortly before the coors sign)
We are planning on having "Fireside" a local hearth and home type store that does maitenance come and inspect and clean it before we fire it up the first time.
I will likely clean the inside of stove myself first though..
![What do I have ? Was it a decent deal, and can I install it like this? What do I have ? Was it a decent deal, and can I install it like this?](/talk/proxy.php?image=http%3A%2F%2Fi1222.photobucket.com%2Falbums%2Fdd489%2FOutkastboss%2FYotul%2520Stove%2FCloseupoffront_zps48ba5947.jpg&hash=b9e1b602a47071a6b4e4a38cb3277416)
![What do I have ? Was it a decent deal, and can I install it like this? What do I have ? Was it a decent deal, and can I install it like this?](/talk/proxy.php?image=http%3A%2F%2Fi1222.photobucket.com%2Falbums%2Fdd489%2FOutkastboss%2FYotul%2520Stove%2FStovepipepic_zps9204ab9a.jpg&hash=69ae697d811af64d4e85bc12f2262a7b)
![What do I have ? Was it a decent deal, and can I install it like this? What do I have ? Was it a decent deal, and can I install it like this?](/talk/proxy.php?image=http%3A%2F%2Fi1222.photobucket.com%2Falbums%2Fdd489%2FOutkastboss%2FYotul%2520Stove%2FWallpassthroughandetc_zps34c9b0d2.jpg&hash=83863ad4a4b4667ebdc599afc9263d2c)
![What do I have ? Was it a decent deal, and can I install it like this? What do I have ? Was it a decent deal, and can I install it like this?](/talk/proxy.php?image=http%3A%2F%2Fi1222.photobucket.com%2Falbums%2Fdd489%2FOutkastboss%2FYotul%2520Stove%2FChimmneypipe_zps4a127b22.jpg&hash=67d5da0369fb828035ef156dae1fdf4e)
