Upland was tested by Arnold Greene Labs, which I think was in Auburn. MA. They were a fully approved lab. Other labs cannot use the UL logo, they can simply use the test standard # - such as "tested to UL 1482 by Arnold Greene Labs".
Back in the "days", labs had to pass even more certifications - ICBO, SBCC, etc.....now they have banded together under IBC (IRC).
In the case of liner, let me apply a bit of common sense to this - there is no liner that is approved without insulation to meet the same standard as those with insulation. Stainless steel has certain properties, and those do not change too much - not enough for it to become an insulator!
BUT, a company might have tested their liner without insulation in a 12x12 chimney with spacers and then it may have passed the sames standards.....but, then again, so would the other ones have (if they tested)....
So, what to do? If the chimney being lined is in reasonable shape (working condition) and is being lined for "size" reduction only, I would not have too much concern. However, if one of your locals is lining a "loose brick" or other severely deficient chimney with thin flex and no insulation....and claims this is OK, ask for the manual.....and if that is "muddy" ask for the test report or a fax from the manufacturer. I doubt the manufacturer wants to be caught "red handed", so you will probably get an accurate answer.
