Hello from Europe.
I've been reading this forum for the last 5 years. I've built a greenhouse to dry firewood after seeing someone here do it.
While I'm happy with the results, this year I bought firewood way too late. It's pretty close to being green.
I want to speed things up a little by installing some fans inside the greenhouse. The problem is I don't have a lot of budget.
What I was planing was to buy some cheap box fans to put them on the top to move air around much faster.
The problem I'm facing is that I'm not sure if those can handle high temps when the sun is up. Max temp I saw is around 60 celsius.
Will those plastic box fans stand that much temp + uv + humidity inside the greenhouse?
I'm planning to just recirculate hot air inside, no extraction/exhausting air from outside. Some air exchange happens naturally because of the way the doors close imperfectly.
What do I need to know? Anyone using cheap fans inside their greenhouses to do this?
Thank you in advance for any help I might get.
