You should not under any circumstances have to leave the door open for 1 hour! Is that a combo alarm?
No, it is only a smoke alarm. It stopped after a few minutes. I am ordering a few good ones off Amazon, I would really like to have a CO alarm...
Paint curing can set off smoke alarms, and it can happen a few times each time the stove reaches a new high temperature.
Just as a safety reminder, do you also have a carbon monoxide detector installed?
Finally, if you end up needing to turn to a compressed wood product and you’re anywhere near Richmond, check out Liberty Bricks. They’re cheaper and better than the ones from Tractor Supply in my experience.
Thank you all. Eventually (after an hour or so), I closed the door to the stove and closed the air intake to 1/2. I started feeling that the stove was getting heated up as it was radiating heat much better everywhere and the ambient temperature started climbing. I will test my wood tomorrow and will also go out and get a stove thermometer.
One odd thing - the smoke alarm keeps coming on - it is about 8 feet away from the stove in the corridor next to the room the stove is in. I can see no smoke with the naked eye. The smell of that first burn paint though.....
You're having trouble with keeping a flame going and *probably* have wet to boot: Keep that sucker running flat out! Run it open, let it get hot keep it hot. If the room/house gets too warm, open a window. Same if the new stove smell gets to be too much.
My priorities:
- Safe wood stove and chimney system design, installation and operation
- NO CREOSOTE!
- Heat the house (distant third compared to the first two)
By burning wet wood and choking the fire down, guess which rule you're violating?
Good luck.
The compressed sawdust blocks work well, so long as you let them burn up and don't crumble them in your stove. Tractor supply is a good source for them.
Compressed fuel sawdust bricks or logs that have been compressed under intense pressure. They are bound by natural lignins in the wood. Duraflame logs should not be used. They have paraffin as a binder.What are compressed sawdust blocks??? Duraflame logs or similar???
How can you tell the difference?I'm not sure what Lowes will have but Tractor Supply sells Redstone Fuel Blocks in 3 packs. That would be worth a try.
Note that compressed fuel frequently comes in two levels. There are cheap logs and bricks that are made by lower compression. These are usually more flakey and fragile. They burn quickly and leave a lot of ash. I would pass on them. Then there are the highly compressed products that are made with special equipment that compacts the sawdust under tremendous pressure. These are a premium product and what I'd recommend buying.
You sure have!I have done an absolutely OUTSTANDING job of hijacking this thread. My apologies. Look for a new thread.
Hopefully oddodaoddo is catching this vicariously and will try it too. There are lots of threads on compressed fuels and I posted some tests a long while back here:I still haven't gotten around to burning Redstones. EcoBrick and BioBricks are pretty good. Give the Redstone a try. Add a brick together on the coals with your regular wood on a reload. It will be dry and ignite. That will help drive out moisture from the wood more quickly and you should be able to close the door in about 5-10 minutes.
Yeah, my psychic powers are getting weaker. Head over to the Classic forum for answers on running the Grizzly.You're assuming I know what I'm doing!
I grew up with central heating and air conditioning, I don't know the first thing about using a fireplace!
Hi oddodaoddo, you would benefit from a local wood-burner, neighbor and see what they have to say...
...there's a lot more to this woodburning than meets the eye, but no, it's not rocket science either.
Good luck with your new stove.
