A question just came up over in the gear room, and I didn't know if it has been asked over here, and I think it's a significant potential issue...
Probably all of us that process our own firewood have encountered foriegn objects embedded in trees from time to time - most common is probably nails and such, but also I've heard of all sorts of other hardware, some of it larger...
Sometimes it gets found by hitting it with a chainsaw, but a lot of it can be surrounded by wood that has grown over the object, and the only way that it gets found is when you dig it out of the ashes...
It doesn't seem like a big problem for wood stoves, but what about gasification boilers? Would it cause problems with plugging up the slots? If the object falls through, what happens to it in the secondary burn chamber, which seems up in the melting point temperatures, at least near the center of the flames... Does it pose any risk of damage to the ceramics?
Gooserider
Gooserider
