Look up "easy-pour" spouts. They completely eliminate the valve, but still have a cap that seals tight to keep your gas from evaporating off.Wish No-Spill would make a spout-only that would fit common thread sizes of other make cans
Yes, that is a problem. The easy-pour spout comes with a vent you can add. I, however, don't really like the style of vent they have (I don't think it keeps the gas from evaporating very well). My simple solution is to add a metal valve-stem to the can in the area a vent would go. Remove the valve core and use the valve-cap as the sealer. Caution: some rubber O-rings included with valve stems are not compatible with gas, I replace all mine with Viton gaskets just to be sure.This is a good idea, but keep in mind the new cans don't have a vent hole, so you will still get the "glug, glug" effect (unless of course you create a vent)
Most of them are also not compatible with gas and they get weak over time. Every item I'm considering using on my gas cans gets tested first in a glass jar of gas in the shed so I can see what happens over time. I've put entire rubber valve stems in it before and they swell up really big and at the end of a 4+ month test they are almost completely dissolved. That's why I went with metal stems and I replaced the rubber gasket on them with a viton gasket.As a side note...the rubberized valve stems kinda suck. They are easily broken (on third one for one of my cans now).
After the husband of my wife's friend died a couple of years ago, I was invited to get what I wanted out of the garage. He had four old style 6 gallon gas cans. Between those and all the one and two gallon cans I already have, I'm pretty sure I'll never have to experience any environmentally friendly jugs.
Good for you! The old stuff was built to last.
Does anyone know what the EPA thought they were solving?
