Well.... This ain't happening fast.
Camben
42
PA
My father in-law and I got our tri- axle last week. This is going to be a slow process. I was shocked when I pulled up to see it. He left for vacation today so I started working on it
[Hearth.com] Well.... This ain't happening fast.[Hearth.com] Well.... This ain't happening fast.
Well, you have a mess there Camden! Be careful breaking out those logs. Getting a good start on it while the weather is cooler is the best way to tackle it. Sure beats working in that heat of summer.
Do you think that maybe your FIL is laughing at how the delivery just happened to coincide with his vacation departure??
Also, welcome to the forum!
Lol, it was pure coincidence that it happened that way... I think. I texted him a pic of what I was doing as he was sitting in Miami. He and the other people that are with him had a blast at busting my chops for the mess I am in. It didn't go too bad but I can see what you mean about the logs shifting. I had one let loose on me while I was sawing. I guess I should just drag them down to the ground. My new chainsaw is working great to. I'll just try and chip away a couple hours at a time. Hopefully when it's all said and done we are hoping for 5-6 cords. Does that sound right to you guys?
Reactions: Backwoods Savage
You surely do got some work to do. Wow.
but, hey, BETTER TOO MUCH than too little.
TWSS;)
Camben,
I'm curious what kind of hardwoods do you have there?
byQ I'm not sure what all is in there. My FIL said it was mostly red oak, white oak and I think hickory but I'm not sure. I'm really bad at identifying trees. What's the trick to figuring it out? I know he said there was some stuff in there that was miserable to split. It was really white in color and very stringy.
Some pictures of splits and bark, and you'll get some ID's. Unfortunately, I'm in a non-oak area so I won't be able to help you.
Green Hickory is stringy and white. Very hard to split using an Axe. But it can be done. Take small splits off the sides all around till you're at the heart wood.
Welcome to the forum! And that looks like it'll keep you busy for awhile! If it were me I would try to get it done sooner rather than later, before the heat and bugs start to make work outside a little less pleasant. If you have red oak, it will have a distinctive smell when split, that you will either love or absolutely hate. Red oak usually splits easy unless you are working on knots or crotches. White oak has a more pleasant smell and can be a bit stringy when splitting but, as stated above, hickory can also be stringy. If you can we'd love to see some pics before and after splitting!
What a mess...but a good mess. Be careful, and think, and rethink every cut, that one log you're standing on while cutting could shift, as so can any of them......safety gear a must.
Reactions: Missouri Frontier
When I cut my pile up last fall, I invested in a heavy duty chain about 30ft long from homedepot, I pulled each length off the pile with my truck and cut it up on the ground, its not worth getting crushed to death, especially if your working the pile alone with no one home.
I know the feeling.
I took a 50 yard truck load a few weeks ago.
At least you have some room to pull the logs off or let them roll down.
I'm wedged in on the side of my garage.
Hey lets see which one of us can get done first and how many cord we pull out of it!
Reactions: CTFIRE
Or possibly elm?
View attachment 131208View attachment 131209
I've never stood on a pile like that, but I've read that historically, working one is THE most dangerous part of processing. Once you get through the first bites you'll get a system and start to see progress.
Yeah, I'm not sure how to tackle either. I've just been sawing off the logs that I can reach. I guess sooner or later I'm going to just start chaining them up and pull them down. I'm thinking of getting some stringers and hopefully get lucky and pull the logs on to the stringers so I can cut them up easier
Reactions: Soundchasm
Congrats on the load. Some of the tools I find helpful when cutting up logs is a timber jack, skidding tongs, and hookaroon. If you have access to a tractor the skidding tongs are great to break apart the pile.
Welcome to the forum Camben.
That may not be stacked the best but it is a lot of wood and you have no limbing to do nor brush to take care of so that cuts out a lot of work. As for identifying wood, take your time. Learn 3 or 4 types well this year and next year add a few more. That is the best way but you need a positive ID on the wood too and sometimes that is difficult on the forum to do as many have differences of opinion and giving a positive ID from a picture can be extremely difficult. If you had a forester near you that could help that would be great. Many times farmers are good with ID but don't think they all are because the farmers of today are much different than the farmers of yesterday and many have never worked with wood.
I would also cut some of the ends as they are stacked and you should be okay with that. Then if you could get yourself a cant hook, you will find that extremely valuable not only for this load, but for the rest of your life. I am partial to a wooden handle like the one pictured below and also a hookeroon (pickeroon is the same thing) can be handy but the cant hook if you choose between the two.
[Hearth.com] Well.... This ain't happening fast. [Hearth.com] Well.... This ain't happening fast.
In addition, you could save yourself a ton of work if you stand that splitter up so you can split vertically. This way you don't have to pick up every log before you split it. Simply roll the log to the splitter instead of lifting it. The old fart below sits on a milk crate (hot seat on the crate) for splitting. No lifting required.
View attachment 131256 View attachment 131257
I was thinking of trying to get an app to help out with tree/wood ID. I can tell cherry,maple,sycamore and some oak but that's about it. All the other stuff I haven't a clue. Question about the cant hook... Can that move big logs or will I need to cut them down? Is it just used for leverage so I can get something under the log for sawing? Can I buy one at Lowes or Tractor Suppy? The splitter will go vertical but I've never used it like that, maybe I'll give it a shot this week. I going to keep at it a little at a time. It's a great excuse get some alone time!! Lol. No kids and wife for a couple hours does a body good.
Is that you by that mountain of splits Backwoods? Nice setup! How many cords is that supposed to be Camden? It looks like 10+
My father in law thought it would be 5-6 cords. I'm not sure though, what do you think?
I would definitely get any piece free of the pile before cutting it. Just be completely paranoid of getting crushed by a shifting log as you pull it apart. Never cut on a pile of logs. It just isn't safe. When putting it on to stringers use about 4 or more. As you cut the ends off a log it will remain stable still on the inner stringers. Handy with the the logs that aren't straight and don't want to be rolled or you have to cut in the middle to handle. I somehow knew the first time I had a tree service unload in my back yard that it had to be laid out as flat as possible and on stringers. Fortunately tree service logs are pretty big and the guy that I get logs from has a rear mounted arm so he has a long reach can lay them out far behind his truck. Usually I have no more than one log nested between the adjacent two. That way I only have to think about what one piece of wood will do when I move the piece in front. Loggers don't usually have that and seem to prefer to unload to the side.
Take Dennis up on his advice on a cant dog/peavey and pickaroon. I prefer a peavey only because you can stick its nose into the ground when done using it. No bending over or finding a place to lean it. A plain old 6' pry/digger bar is also very useful on logs and log piles. You can use a bar to lift a log up onto your stringers.
