Wood,
I got a few smiles with that read.
Since this is my last house, and I want what I want.... I am proceeding as planned.
The few hundred for the blower door test(s) will be put instead to the upgrades I am doing.
I can always get it done later. There is still issues of sealing the basement sill plates, windows the bilco doors that have no interior door at the basement wall etc.
I am ready to start installing the 2" polyiso I bought for the bedroom. Yes, it should still be pretty well air sealed after sealing the seams, & foaming the perimeter.
With the added R13 from the iso, that gets me close to R43, close enough. When I do the roof, I can always have a lil feller crawl in there and blow some cell in there, or just take some plywood decking sheets off and blow in from the roof. I don't care for white, paint, etc. I am a wood lover. Natural finish, that is why I am torn in replacing the T&G with new. But as budget constricts, I will re-use the dark for now. I can always install new natural to the dark later.
And to poly the who thing for door test, don't forget the peak is 3 stories, and the entire ceiling is T&G. 43' x approx. 35'. It is not a little ceiling.
Surprisingly, the house is not super dark. The light colored wall, and tall windows do a lot for light.
The "chimneys" I am still weighing in on. I am leaning heavily towards widening the bottoms, and maybe the tops also, and insulating the piss out of them with iso also.
Yes, when I do the roof, new windows will be installed. The PO put some flowery stick on film on the insides, which is now dried out, and faded, blackened and falling off. Looks like bad shrinky dinks.
Although the film still on them is baked on. Will take some scraping with razor blades.
I will be screwing lath to the bottom of the iso into the trusses to mount the T&G to. I may even seal between the lath & iso with silicone. Whats a little overkill?
The issue with the batts, is the prior owner stapled them to the inner sides of the truss chords. There is a triaxle wind tunnel gao the length of the truss chords on each side of every truss where the insualtion is up due to the batts being stapled on the sides rather then the bottoms. I pulled all the staples and reset the batts, and re-stapled them to the bottom of the truss chords. The upper side wall where the T&G were only had crappy batts also behind the T&G. I pulled that and installed Roxul R23. And drywalled over the open area. T&G will be reinstalled over the drywall directly. Already have my first coat of mud & tape on. Also sealing up wires & such.
And filling in with Roxul, where insulation was missing along the ceiling/side wall area in the attic. Just enough room to poke my head up there to see where it was needed.
Yes, it is a HUGE PITA, but I love working with my hands, and love improving my place, so it is worth it. Plus I love the challenge.
I hate it at times, but the end results are always very satisfying.
I am still weighing ordering new natural clear satin finished end matched T&G.
Found a place in NY that advertises .95 per foot. May be able to pull that out.
Now natural finish ceiling & skylights,, plus opening the skylights top & bottom, would probably be drastic, in a good way.
I'm in no rush. I was not even going to start it this year, but could not help myself. The living room, at 3 stories will be a major challenge, which I welcome, at least till I'm up there tearing away.
I do like your thoughts, but am too set in my plan.
Thanks
Thanks
IIRC you have the lovely T&G entryway, right?
