Search the old threads, even call Don,I bet he remembers .Harman gave you a generic answer.They would assume older stoves have already been "upgraded".
First off, thanks for that parts info; yeah, I should have Searched but I am not certain of the best search criterion. (a) Wow, I cannot tell you how much I’d rather stall, if at all possible, until end-of-season so I would feel more comfortable about ripping the stove apart and perhaps finding a problem (meaning I do not understand what I am doing) with the stove then out-of-use for days or even weeks — at the coldest time of year when I’d like to run the stove daily. (b) hmm, this might add up if I replace the burn pot, the ignitor, the ignitor cradle, and should I replace the flame guide? Moreover, might as well do the auger motor with I’ve deferred. (c) So, reading the instructions (gee, I wish there were pictures or video, every time I hit YouTube on the Accentra they only show the non-insert version), it sounds like removing the burn pot simplifies getting access to the ignitor… great, because I really do not see how one changes the ignitor through that tiny access door, rather a ship-in-a-bottle task if I ever saw one. By the way, who is “Don”?
Well, Saturday morning, I turned on the stove hoping the 25-minute light-off was an anomaly. Not! After 25 minutes I got a shut down and 5-blink error message. Sigh. I really wanted a fire so, for only the second time, I attempted a manual light with gel (the first time, a year or two back, I failed). I had read a few posts before mentioning soaking some pellets in gel for several minutes, and leaving the door open for a bit after lighting. The good news is that I succeeded, and the stove ran. I admit, there’s a lot of question in my mind on how much gel to put on how many pellets, whether to has some dry pellets in the stove and the gelled ones on top, or vice versa, and how long to leave the door open and by how much. It looked like the flame was going out, I moved the door around until it was open just a crack, and that got a stronger draft like a Venturi Effect, and several minutes later got past a stage where I only was getting blue “gel flame” to orange “pellet flame”, and then could close the door and it almost went out, then it slowly took off. Sheesh! If there’s something I am doing wrong, please advise me.
Anyway, tomorrow AM I plan on yet another front end cleaning. This is based on the possibility that four 15-hour burns dirtied up the stove, maybe the holes in the burn pot, that it makes ignition difficult/impossible. It it returns to “normal” operation, I guess I will need to do the cleaning every four days. Again, sheesh. If it fails, I might be doing manual/gel lighting for a while, and then I need to decide on if I need to tear into these part changes myself or call in a professional (I suspect techs are thin on the ground around here).
