I have two 60 ft coils, 120 ft total. They are supplied by 1 inch copper line in parrallel, in that water does not run thru first one and and then the other, but that each coil recieves same temp water by dividing the 1 inch line into two 3/4 lines then reuniting lines after coils. I know That is less than a lot of folks with technical expertise recommend, but it works good for me. It is controlled with valve in that I simply adjust flow to tank coils based on heating situation and then whole system slowly cools and supplies heat after fire is gone. Obviously not a high tech system and I would probably use primary secondary type of plumbing if I had to redo but I did not know of this site when I did it. I ahve a royal 6150 boiler which is a good unit, but again not a gassifier. Missouri climate is moderate and I have lots and lots of wood.
TAnk is 500 gal made out of 2x4 with 3/4 plywood and 2.5 inches of polyurethane insulation and 1 inch of blue board foam on exterior (between 2x's) and 1 inch blueboard on interior behind liner oer 3/4 plywood with osb on exterior. Have a single top center support to keep tank from speading on top and 2x4's run horizontal and are bolted at corners. For top I layered 5 1 inch thick blueboard sheets with EPDM on innermost top panel.
Do not recommend use of blue board for high temp. Use the Polyscianate stuff (spel?) I also messed up on installing my liner and need to re do it to have a better seal around top edge. but it holds heat well. Plan to fix liner this summer.
