Spray wax I use on my motorcycle, very high end stuff, leaves no swirl marks.What did you use for wax?
I use whatever old motor oil I have laying around on the wear areas, never had any rust.I was looking more for the metal slide part that gets to be bare metal from splitting
If you're seeing rust, then you're not using it enough.I use whatever old motor oil I have laying around on the wear areas, never had any rust.
xman is that an old mtd mine looks identical except for some decals mine is 15yrs old, Doesn't look quiet as good as yours but then again I have never waxed mine.
Xman, mine is a 6hp Briggs I/C. And don't feel bad I once spent a Saturday completely dismantling and reassembling a leaf blower that worked great just to have a reason to get out of the house, some times a garage is a mans best friend.
It does look real good for a splitter of '94 vintage! Even the tires shine! Hmmm.... Tire black? And then there's a ATV, a go cart and the ever present cluttered work bench! Man cave material!!That looks pretty dam good for 20 years old, I bet you could sell it for a profit and get a new one down the road.....
No tire black on them, guess its the wax in the car soap. Yep, that's a go cart with a roll cage. Between the cart and the yellow generator is a 1972 Honda 350, I can't even see it. I guess it's a man cave, other motorcycles, ATV's. boats, skis, etc.It does look real good for a splitter of '94 vintage! Even the tires shine! Hmmm.... Tire black? And then there's a ATV, a go cart and the ever present cluttered work bench! Man cave material!!
It sounds like a lot of fun guy things in there! The Honda is a collectible for sure.No tire black on them, guess its the wax in the car soap. Yep, that's a go cart with a roll cage. Between the cart and the yellow generator is a 1972 Honda 350, I can't even see it. I guess it's a man cave, other motorcycles, ATV's. boats, skis, etc.
My cord is getting a little worn. Any secret to getting a new one on it?Hey Xman23,
I got the exact same splitter. Bought it new in 1993. Haven't met a piece of wood that it couldn't split. The only problem with the engine is the pull starter chord, with I had to replace a couple of times.
Yea a few toys, How's that saying go, "the guy who has the most toys............" The 72 Honda is mint, 10K miles and collectable. Since I have a pristine Valkyrie it doesn't get used much.It sounds like a lot of fun guy things in there! The Honda is a collectible for sure.
On most you take off the recoil and rewind a new rope on. The Honda's are real easy, but some briggs take more work to get the recoil off. I have done it a few times and can easily have a new rope wound on in 5 minutes. I have myself while learning and watched others struggle until they break the spring and need a new one.My cord is getting a little worn. Any secret to getting a new one on it?
Put the new rope on the reel with a knot in the end and the handle on the other end - make sure it is threaded thru the hole proper. Then with the string unwound wind the reel around without letting the rope loop into it. Some reels have a notch to keep the rope for this process. When you have wound it enough times, with the rope lined up let the reel wind the rope into it. If you did it right you are done. Put the recoil back on and use it.
I must be feeling a little guilty, I left the splitter out in the back yard under a tarp all last winter. Just got it back in PA where I keep it in the basement. I've had her 10 years, and my guess she's about 20 years old. Run's perfect and doesn't look to bad for her age.
