First post...
I've been working on the VC encore 2550 that came with our recent house purchase. I believe it is from about 1996. It looked to be in good shape but needed the refractory replaced as there was a hole in it straight to the stove pipe. So I replaced the refractory and regasketed and installed the upper fireback and sideplates and windows and doors and everything. I thought I was good to go but I noticed that the ash door has a gap in the right edge even when its cranked as tight as possible.
The gasket seems even and I can tell that the new gasket is contacting the surfaces on the rest of the edges. Looking at it with a straight edge seems to indicate it is warped on the last few inches of the bottom edge which would account for the gap. Is there anything else I should try or should I just buy a new ash door?
I've already sunk enough money into this that I can't give up now. Hopefully this will be the last thing in the way of getting a stove that will work well for at least 5 years or so. If it will do that I would be happy and at a later date can replace it with something that is less complicated to maintain.
