Want to purchase Blaze King Chinook - have a few questions
Install this U strut over your wire. It comes in many sizes, the one here is 7/8'' deep and usually 10' long. Look for strut without holes in the back.
  • [Hearth.com] Want to purchase Blaze King Chinook - have a few questions
I am following this thread closely, as I am shopping for the exact stove and will be doing a very similar install (except in the basement). Same through the wall and same total pipe length.
Are the sides of the stove white or cream?
Thanks
The sides are silver, kind of like a stainless kitchen appliance. They are also available in red. Black used to be available but that's no longer available.
Than you.
No more plain black sides? I believe the website still offers them.
Than you.
I asked blaze king directly. They said they we're having trouble getting the black sides to match the rest of the stove. They are easy to remove so you could always try painting the yourself any color you want.
Okay, so everything is done finally. I think I'm going to just leave the wire. If it's okay for the wood to be that close it must not get that hot within that space. Also as far as the conduit ideas, one thing I learned when running some wire in my garage is that Romex should not be run inside conduit, which may or may not be code. Reason being that the conduit acts as insulation and the wire could overheat. Conduit should be used with individual conductors. I'm definitely not an electrician but I did stay at a Holiday Inn last night.
I ended up having to space the wall brackets out from the house by about 1" in order to get 2" away from where the roof shingles overlap the rake board. This pushed the vertical sections further away from the house which meant that replacing the 12" with an 18" section would only push the stove 3 1/2" further into the room which wasn't a big deal. The telescoping section would have been better but I couldn't source it locally and it's $200 as opposed to $100.
As far as ember protection, I ended up just buying cement board, making an oak trim for around it and tileing over that. It's just a temporary solution and we cracked two of the tiles try to position the stove on top of it. I actually bought a stove board from lowes but returned it because not only was it damaged but it was very low quality to begin with.
Thanks for everyone's help with this and hopefully this helps someone else who's thinking of doing something similar.
Also a quick shout out to Alan at Hart's Hearth who was willing to share his considerable knowledge and experience. I didn't buy my stove pipe from them but I should have.
Now I just need to get the building inspector out to sign off on it and I can start using it.[Hearth.com] Want to purchase Blaze King Chinook - have a few questions [Hearth.com] Want to purchase Blaze King Chinook - have a few questions
Reactions: Mark8 and Highbeam
Looks great.
I like the sides actually. Very nice
Have you seen the glass hearth pads, Morso sells them and theyare available from some other sources. Would be real sexy on wood floors.
Wow, that looks nice, I wonder how dead flat your floor needs to be to support the weight of a 700 pound stove on glass with out it cracking.
Zooming in on the photo, it looks like the glass may have a clear silicone pad underneath it. If so, that might buy you a sixteenth of an inch of wiggle room.
I've got a glass pad that was sourced locally and was much less expensive than the morso. It's tempered and would be difficult to break in my opinion.
I think what your seeing is a bead of caulk so nothing gets underneath it....I did the same thing.
Reactions: Mark8
Yeah, but imagine a 250 pound guy plus an 800 pound stove pushing down on it. If the floor isn't even.... that'll break a lot of things.
Reactions: Mark8
Isn't the Chinook 425 lbs?
We were talking about any free standing stove, and the Woodstock is 700 Lbs. I was also thinking like you mentioned , you better have some silicone to keep the dirt from getting under, that would get ugly real quick.
I know metal on glass is real slippery, do you feel if you bumped your stove it would move easily?
Did your glass sit flat on your floor or did it wobble?
How thick is your glass, and did it come with any info or weight ratings ?
I had a 4' x 8' x 1/2" sheet of glass door from a department store entrance and I know that thing was pretty strong. I was just curious what limitations these glass pads had and if a uneven floor would pose a problem.
:Update, I just got off the phone with a Morso dealer and they said their pads are only rated or to be used with a Morso stove.
Its about 3/16 thick. I have an f55 on the glass and it's not slippery or easy to budge at all. It didn't come with a rating of sorts....it was sourced by the local stove shop.
My floor isn't perfectly flat and it seemed to sit high in the back but it didn't cause any problems.
Glass can flex, it’s not that rigid. I think it’s actually just a really viscous liquid.
Ooooh I like the glass. Might change my plans....... Floor needs refinished anyway. Hmm.
