If you don't mind saying what did it cost you?This one. It was inexpensive and in good shape.
Most stoves are going to cook you out of that 700 to 800 SQ ft room. That Fisher certainly willSince we bought the Listed Grandma III it will be nice if it's a usable one, even if it doesn't work for our space.
Our add-on family room is about 700-800 sf but has 9' ceilings and French doors to the rest of the house. It has 3 large windows. We recently removed the aluminum singles and put new double pane around the house.
The bedroom add-on is about 300 sf and has a single door to the house.
The rest of the main floor is 1,300 sf.
The upstairs is 1,300 sf.
The basement and attic are smaller and we are not concerned with heating them really, except to keep pipes from freezing in the basement.
The furnace is in the basement and heats that space.
The furnace heats the 2,600 sf main floor(1,300sf) and upstairs(1,300sf) space.
It would be nice to have solar and/or woodstove backup for everything but we at least would like to heat the 700sf-800sf 9' ceiling family room and extra heat can go to the rest of the space and take some of the burden off of the furnace.
Any recommendations welcomed, please?
I really don't think it would be underneath. Why would lifting with chains matter? It will scratch the paint but otherwise it won't matterWe are really not sure we would like them lifting it with chains from the top.
Less than most for sale. If it doesn't have the UL tag we might ask if we can pay less or something since it really cannot be installed and used in that case. Bummer is, most of the Fishers are not listed. People don't know all these detail rules going into it. It had been listed for awhile so maybe most do know..If you don't mind saying what did it cost you?
What many do, is install to the safe NFPA 211 Standard and claim the stove was existing, since the code is for installation, not the use of a pre-existing stove. You can change the pipe, and chimney and still be pre-existing, since it is difficult to tell when the stove was installed. Hence the used stove market.Less than most for sale. If it doesn't have the UL tag we might ask if we can pay less or something since it really cannot be installed and used in that case. Bummer is, most of the Fishers are not listed. People don't know all these detail rules going into it. It had been listed for awhile so maybe most do know..
  we can keep items that would be helpful in the 1st few days of an emergency. 1st aid, food, water, etc. We could pull all the stuff out and cook with the stove.  We can store it in our shed to keep it out of the weather. Just thinking.You would need a chimney to hook it to when you pull it out.It might be a good place to store emergency prep items in case of fire or earthquake it might be more likely to make it throughwe can keep items that would be helpful in the 1st few days of an emergency. 1st aid, food, water, etc. We could pull all the stuff out and cook with the stove. We can store it in our shed to keep it out of the weather. Just thinking.
				![[Hearth.com] Want to get a Fisher [Hearth.com] Want to get a Fisher](https://www.hearth.com/talk/data/attachments/294/294988-c1db246b4fb291de0cf6f418286c9095.jpg?hash=EwbC1Y11lc)
What kind of chimney were you thinking? There are the stove pipes. We're you thinking of a brick chimney or something?You would need a chimney to hook it to when you pull it out.
It doesn't matter what type. You just need some sort of chimney to creat draft without that the stove simply won't workWhat kind of chimney were you thinking? There are the stove pipes. We're you thinking of a brick chimney or something?
