RenovationGeorge said:gyrfalcon said:What's this about Hearthstones burning fast and hot? I've somehow missed that and find it a bit hard to believe, given the behavior of my Tribute, admittedly the runt of the litter so maybe behaves differently just from its size. It's been my impression that the Hearthstones, like other non-cat stoves, certainly can't do the long low burns of a good cat stove, but I've never read here that they're any worse at that than others. I don't suppose you could point me to any threads here on that subject off the top of your head? I'm really curious now.
As I said, they can burn hot and fast, and sometimes need a flue damper. The guy is concerned about being too hot, so I was addressing that:
https://www.hearth.com/econtent/index.php/forums/viewreply/763623/
https://www.hearth.com/econtent/index.php/forums/viewreply/763563/
And I've seen it in other threads--search around if you like. It's not so much an characteristic of Hearthstone's in particular, but non-cat EPA stoves in general. Ironically, they need a good draft to pull air through the secondaries, but because EPA compliance means their primary air cannot be completely shut off, they can be hard to turn down enough on a flue with a strong draft. That's not a criticism, but an attempt to be helpful.
Easy folks.
I have a flue damper on the Heritage and the Vigilant. Both come in handy.
And for clarification, when you are talking "fast" you mean shorter burn times and not time it takes to get to a certain temp, correct?
