Greetings all.
We are getting to the point of planning out and executing the installation the wall protection for our Jotul F55 Carrabassett and Kitchen Queen 380 (two separate sides of the house) and we are mulling over how best to do wall protection behind each.
I have read that you need a non-combustible material--we are planning to use a tile of some sort over 1/2" cement board. I have also read you need a 1" air gap behind that board. I assume you shim out the studs 1" and then apply the cement board on top.
I have also read that you need a 1" gap between your non-combustible material and the floor, to allow airflow into the air gap.
So, this means we have 1" scabs on the studs, cement board hung 1" above the flooring, and likely some kind of trim on the top of this 1" gap at the top and sides (e.g., square tile pieces; oak).
What does that 1" gap look like by the floor? I assume you can't cover it up, so it would be a gaping hole there, no?
Second question--what height would be safe for the wall protection for each? To say there is a dearth of info in the manuals for wall protection would be an understatement.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Any thoughts would be great! Much appreciated.
