Hello, I have a Wiseway GW1949 Pellet Stove that is classified as a wood stove. The code specifies clearances of 36" (or reduced if with a heat shield) but the manufacturer's specs are significantly less stringent. E.g. according to the manual, the backwall clearance only needs to be 2" instead of 36". It would be quite favorable to go by the manufacturer's specifications in this case as this is being installed as backup heat in a tiny house in Upstate NY. My understanding is that if the stove is UL Listed I can go by the clearances specified by the manufacturer, but which UL standards does it need to comply with?
According to the manual:
"Your pellet stove has been approved for installation in the USA and Canada. It may also be installed in a manufactured or mobile home (for USA only) . Your stove conforms to UL 1482-11 (R2015), 2010, and Certified to ULC S627-00, and(UM) 84-HUD". Is this sufficient to go by the manufacturer's specs?
