vigas boiler
This is a well thought of boiler on the UK forums. They are new here & I don't think you will get a lot of personal reports, at least US anyways. There is a very well done You Tube video on the standard non Lambda one you might want to check out, Randy
Henfruit; You tube has other boiler videos also & along with Hearth feedback should help with your decision, Randy
Tarm Sales Guy said:
is this boiler tested to UL standard?
Yes Chris & CSA Canada. I wish we would just accept EN303-5 though & then everyone would have a lot of fine boilers to choose from, Randy
henfruit said:
Any feedback on the vigas boiler?
Well, here goes my first post....
I've been reading the forum for a while now, and have learned alot.
I went to AHONA and Mark demonstrated the Vigas and the Biomass.
After the demonstration of the two units, I ordered the Vigas without hesitation.
The quaility, ease of use, and "automation" from the control panel and the lambda makes it easy to use.
I am currently waiting for the unit to be delivered, but I will post updates as I progress.
My plan is to install the unit in parallel with my oil boiler, and I have already purchased 3- 240 gallon vertical air compressor tanks (new) for pressurized water storage.
Welcome! Compressor tanks are a good choice, most in that size are ASME. Lambda boilers are nice & I look forward to your reports, Randy
