Bob, I hope you don't find that you end up having your boiler shut down more than you like. Only way you will know is to try it I guess. Will you be able to adjust setting easily for high temp shut down?
Just a thought - can a barometric damper be installed on the stack of a Woodgun?
Just asking as they can make for a very easy to use cleanout spot - just push the damper open & clean it out through that opening. Saves messing with caps etc. - could even wire it closed when not cleaning if you had to.
Yes - that's what I wasn't sure about. A baro isn't air tight.
Mine doubles as a cleanout spot - but I've got draft sucking from the top of my chimney and no forced draft fan.
I suppose some sort of variable speed fan setup likely isn't an option either is it? One that would ramp down as the fire dies? Sort of sounds like when the fire is down to coals, the fan is pushing way more air through than is needed which is pushing hot coals/embers where you don't want them. And likely dead ones too at other times, that then build up & eventually cause what you experienced. Might just be a nature of the beast though.
The problem is that once your sensor detects the high temperatures, the charcoal fire has already started. Perhaps you're thinking that by shutting down the combustion fan the fire will extinguish or at least not be so intense?
I think I had read previously that a variable speed fan on the WG would be very expensive? Fred, since under normal circumstances the temp does not exceed 500 I'm thinking that in the best scenario if the temp hit 550 and the boiler shut down I would catch it at a time desirable but at the very least I cut the air flow to minimize the possible fire. Upon next visit to the boiler it will be off when it should have been on and I'll know enough to pull the cap and clean out any coals in the pipe.
The residue was all grey...nothing dark and it was a very fine power. Gas, I was hoping the cyclone was blocked as I would prefer that than trying to control chunks of hot coals entering the the horizontal run but when I pulled the ash back toward the cyclone it fell thru the vertical pipe and wound up in the pan. Actually, I don't think my cyclone has ever been blocked. It's cold here today too but not too bad, just came in from the barn and it's creeping toward 30 now.
Ken, I agree. I clean the boiler on a regular basis, just one more activity to add to the routine. I need to find an easier way to remove the cap on the T if I'm going to be doing this routinely. Thanks again for the info.
Fred, I am surprised that this happened now with the nozzle being barely a month old, I would have thought this would more likely have happened when I was stretching the use of the old deteriorated nozzle! The higher stack temps that I have observed have happened only when down to nothing but a thick layer of coals. Yesterday I cleaned the box of a lot of ash and some of the coal bed down to probably only a few inches thick. I noticed this morning in mid run that the stack temp was only 325-350.
My solution will be to install high temp sensor that will shut the boiler down. Giving my electrician buddy a call later.
Bob, attached is the schematic with the fan shutoff shown conceptually. Don't know the details of your existing fan control circuit, but the alarm/shutoff contact would be wired in series with this circuit. If you wire to a normally open contact and the Tx Controller is powered off (i.e. contact open), the fan circuit would be disabled (i.e. interlocked from running). This is the most conservative and fail-safe way to wire the circuit. The $100 Tx Controller I ordered from Automation Direct has three alarm contacts.
