Just thought I'd share the VC Vigilant Operations Manual, Installation Manual, Parts List and Service/Rebuild Manual (generously provided by Kenster).
So if anyone needs any, or all, of these please let me know.
I would like a copy please patrt2@gmail
.com
thanks
This is to load the manuals up there correct? Just want to be sure I understand. ThanksI can upload to the wiki if you want to email me at webmaster(at)hearth(dotcom)
Gotcha, the one I have covers the 4 and I also got a copy of the Vigilant II Service manual from "Kenster" that I cleaned up and put into a single PDF document (great for the "rebuilders" in the Hearth community). Thanks again, love this siteYes, we have some of them there already......
https://www.hearth.com/talk/wiki/vermont-castings-older-stove-models/
In fact, there is one manual for the 4 stoves - there. So if yours is that same one, we don't need it. But if yours is not there and you want to add to the collection...
I have an older Vigilant (2 pc fireback) and need to rebuild. Does anybody have advice for this process or pitfalls to avoid? The stove leaks pretty badly in the front panel to side joints and I wondered if this is typical. Love the stove and don't want to scrap it so rebuilding is the plan!
Hi,
Yeah these are great stoves.
As far as Diss-Assembly be careful with removing the nuts holding the Tie Rods (four 1.5' threaded rods that hold the top plate to the bottom). Soak them with PB Blast for a few days before attempting to remove. Mine came off easy and I was able to leave the tie rods attached to the top plate (was allot easier than trying to remove them and reassemble). The top of the stove sees allot more heat than the underside of the bottom plate, I think the tie rods would just snap off from the top plate if you tried (that would NOT be fun). Unscrew, if possible, or dremel off the nut holding "Cover Plate-B" that is attached to the Fire-back first. Get a replacement nut & bolt. My stove came apart fairly easy, it’s not scary as long as you make yourself familiar with the Service Manual Instructions.
I received some great direction from www.grahamthestoveman.com for Re-Assembly. He pointed out that these stoves almost always have some degree of component warpage making re-assembly challenging. For my One-piece fire-back the issue was that "Cover plate-A" (the air channel attached to the back of the Fire back) had a small amount of warpage that I had to adjust with my dremel. The reassembly of the Side-Plate, Cover-plate-A, Back-plate & Fire-back is a puzzle, definitely get a second (or even third) set of hands to help out (I had three and it was MUCH easier). So if you go to the sites Wiki and download the Vigilant Service Manual it gives the exact directions for your Vigilant II 2 piece fire back model.
Graham said the re-assembly sequence is
1. Back, 2. Left Side, 3. Fire-back. I did this sequence but added the following.
Follow Grahams' sequence above but add;
3a. Cover-plate-A in channel
3b. Fire-back (make sure cover-plate-a & fire-back seat together).
4. Damper & Smoke Shelf
5. Front
6. Right Side Plate
7. Top
ADD
8. Replace Cover-plate-B through vent-hole on bottom right of Fire-back with cement & new nut/bolt. Will require someone holding a flashlight and a good sense of "feel" to be sure it's seated and attach nut and a boxed end wrench to hold it in place while you tighten the bolt with a ratchet from the stove side.
This helped ALOT! Trying to get those 4 puzzle pieces together was near impossible without doing this extra step.
I wish you well, these are the things I ran across in my rebuild journey, yours may be different but I hope this helps!
Thanks, we'll give it a shot and see how it goes! I am in CT and have looked for a service person I could trust to do this and have not found one. Graham pointed me to someone in Old Lyme but the number was disconnected! I had two stoves rebuilt at the factory years ago and it was absolutely great, they were like new for almost no cost. Wish VC was still alive in Randolph.
Hi All,
Enjoy all !!![]()
Hi All,
Enjoy all !!![]()
Hi All,
Enjoy all !!![]()
Hello Vigilant79,
I've just picked up a Vigilant 1A (single piece fireback... well, it used to be) from a less-than-honest Ebay seller, and it looks like it's going to need a full disassembly and a lot of work to get running efficiently.
Given the state of this Vigilant (which has long since lost its gaskets, been mercilessly overfired, stored in a damp barn for a while, before being given a coat of stove black and sticking on Ebay as "good condition") I'm almost certainly going to have to do some grinding/welding on some parts to reassemble.
I already have a 1979 Resolute (aka the "Old Resolute") which I've partially restored in the past, so appreciate what the rebuild is likely to consist of, but I'd much rather have an authoritative guide to work from, especially if having to cut/grind warped parts to fit.
Please could you possibly e-mail the service/rebuild manual, as it will save me a lot of head-scratching!
Regarding the now-two-piece fireback, I'm more concerned with a good fit to the air-tube castings behind, and to the fins that seperate the flueways than I am about aesthetics. It's for my own use, so if I can effectively refit it in two parts (or drill/tap holes and use bridging plates), and gapfill with fire cement, I'm ok with that.
As much as I'd love to give it a full restore (Vigilant 1c kit seems to be available at The Cozy Cabin), I just can't justify the >$500 + international shipping at the moment.
Hi All,
Enjoy all !!![]()
Hi,Hi All,
Enjoy all !!![]()
Hi, no but you can find it here: https://www.hearth.com/talk/wiki/vermont-castings-older-stove-models/Do you have a manual for the old resolute. I picked up one in good condition and installed it in my home, but being my first wood stove, id like a manual to look at. thanks
Hello Vigilant79,
Hi All,
Enjoy all !!![]()
Hi All,
Enjoy all !!![]()
