wooduser
Unfortunately, that indicates a bad electric gas valve.
650 millivolts is actually more voltage than you ought to have. That suggests that the pilot valve electromagnet that holds the pilot gas on when you quit holding the valve open is bad, the circuit is open, not using the millivolts it should to energize the electromagnet..
You can check the resistance between TP and TH/TP ---- you'll likely find that an open circuit when the circuit needs to be complete to energize the magnet.
The millivolts drop when the switch is turned on because they are being consumed by the main burner gas valve solenoid when it is energized.
I recommend against DIY replacement of the gas valve. It's just more than a do it yourselfer should take on, and the main burner gas pressure needs to be set when the new valve is installed. That's my bias, anyway.
You might want to make a note of the make and model of the electric gas valve when you are shopping for service. A repairman ought to be able to bring a suitable replacement valve with him with that information.
Sorry this wasn't a simpler repair. A bad spill switch or bad thermopile would have been good DIY repairs, and much more common than needing to replace the electric gas valve.
