I was wondering if anyone has replaced their vermiculite baffle at the top of their stove with a steel baffle. My has cracked over time and I need to replace it. Was thinking of using steel just wanted to know if that was ok to do.
I had a regency insert that had the fragile vermiculite baffle. After breaking one twice I made a new one out of 1” steel plate, worked great never warped.
What are you doing to your baffle that you keep breaking it? Mine is 10 years old with no problems. The problem with steel is there something not much of anything insulation value there and that means the fir box temps will be lower. Not to mention if it really is 1 inch thick you now have 100 lbs resting on the tubes meant to support 10lbs.
Oh long story. Stove was in the great room of a lodge we used to work at. Guests would often use the stove over the weekends in the winter and where obviously rough with it.
Still though 1” thick!! is way too much. Think I would have tried 3/8”. The old lopis would use firebrick and lightweight angle iron supports but those didn’t bear their weight on the thin tubes.
a piece of 1/8" stainless with a lot of holes in it over the tubes but under the vermiculite baffle would provide the protection you're looking for and keep the same insulating quality wouldn't it? I think i remember someone on here making something like this.
Agreed it was goofy and overkill, we had some 1” plate plate kicking around, was my dads idea, lol. Pretty sure the stove is still in service 15 years later...
Never a good idea to modify an appliance, hard to explain if there is ever an issue. Ceramic baffles hold up well unless they get whacked and/or messed with. My Enviro's is 8 seasons old and are the original, but I will admit I have a spare set along with an extra glass if ever needed- so far that has worked, just having them "in case of...."
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
