Okay, so, the pipe goes out, but it's too close to the window, so I'd put a 90 that goes both up and towards the bath, you know, on a diagonal, then a 90 that terminates. No need to go out from the house, as you originally proposed. So, in total a 45 inside the home, and two 90s, but set at a diagonal to do what you were trying to do with three 90s, and terminate without have to go out away from the wall.I wanted to send off the picture that smokeythebear requested. Here is my house. The porch is to the right. If you measure 11 inches to the left of that exterior porch wall, that is the location of the interior wall. Hope this helps? I'll get back to Bags soon.
![[Hearth.com] Venting through interior wall, then outside? [Hearth.com] Venting through interior wall, then outside?](https://www.hearth.com/talk/data/attachments/143/143691-08328abce20f2c7f61343ecb69586a3c.jpg?hash=Df5isHDJKH)
![[Hearth.com] Venting through interior wall, then outside? [Hearth.com] Venting through interior wall, then outside?](https://www.hearth.com/talk/data/attachments/143/143791-890eee7503a399c481545e6d75332bb2.jpg?hash=0KpILy8D7R)
![[Hearth.com] Venting through interior wall, then outside? [Hearth.com] Venting through interior wall, then outside?](https://www.hearth.com/talk/data/attachments/143/143873-28c079fddd635d8138a4df430a481cf3.jpg?hash=FRswrPTOGt)
Out of curiosity, what is that white band on your roof at the very bottom of your shingle just above your gutter board and soffit? Looks like white metal? ? Why is it there and what is it? Thanks
Yep just installed one in my cabin for the second stove.Found better prices at unbeatable sales,but things change daily.I think they make 3" and 4",and 2" or3" oak fitting,but the 3" oak comes with a reducer.More info on their website,and hole for pipe is big enough to use other mfg flue pipe,but check.Thanks again guys. So it sounds like there's some agreement that Bob's suggestion may be a way to get around several problems. I like it. That gives me 2 more inches away from the porch, and should allow me to then clear it when going straight up.
I found this. Bob could you confirm that this is the thimble you are referring to? http://www.amazon.com/DuraVent-4CAS-WTPK-Inner-Diameter-Combustion/dp/B005EZ7158
So with a 45, clean out T, 90 jet cap, this is certainly 4", correct? But it's a nice straight vertical venting. The preferred solution.
Yup Smokey nailed the metal roof border question from bags.
I don't know which DTV birds I'm pointed at. I just know that it's pointed almost perfectly SW. The wall where the pipe exits points SSW.
Great! Thanks Bob.
Smokey.. You've provided lots of great input throughout this thread... Given this new thimble option, do you agree with the plan suggested by Bob?
And although it's straight and simpler, it's still going to be a 4 inch pipe, correct? I would need 12 feet of vertical pipe with a 45, clean out T, and 90 jet cap. And I'd use the OAK.
I'm feeling like starting a weekend project ;-)
I received more responses and great suggestions than I expected I would on this thread. Sincerely.. I'm extremely grateful.
I priced everything out. Looks like $400+ no matter how many deals I find. Unless I find some used stuff on Ebay.
At that price, this may take some time to get all the parts, but I will post pics of the final product when finished.
Thanks for the pointers in the last post, Smokey.
