Hey all,
I've been reading posts for some time and searched for my situation, so as to try not to waste anyone's time. But haven't quite seen it. I installed a ComfortBilt stove last year, connecting a Duravent PelletVent Pro 90 deg elbow to a tee to an existing chimney pipe, and all went well. This year, I'm adding a stove to my basement, and not so lucky.
I'm using another ComfortBilt stove, running out a Duravent PelletVent Pro 90 deg elbow to a tee, up 4' to another 90, out 2' to the Duravent cap (using their kit). I've had loads of smoke through the elbows, at the creases/bends that I didn't think needed sealing. I sealed and sealed, no real luck, having especially bad leak from the tee cap. I taped and all, not much better.
I finally took it all apart and realized I'd botched the elbow to tee connection, not fully seated. Great, hoped this was it, but guess what. That connection won't allow for a seated 90 deg to my stove (perpendicular from vert tee to horizontal to stove). I can be up about 30 deg, or down a lot.
So, key questions are -
Why can't I get the angle? (upstairs unit is same and worked fine, fully seated.
Can I "over crank" the Duravent pipe? As in, can I force it to turn farther and still maintain a good connection?
Am I partly experiencing a mistake in pipe width, and need to to go to 4" since the math I usually see has me at EVL of 19, a hair over permissible?
(I'd talked to DuraVent last year and they thought my original install was fine, but it quickly went to wider chimney after elbow and tee.)
Pics show my overall setup and the elbow angle problem. Other important details would be that I want this particular setup in order to place the stove on an existing mat, centered in front of fake brick backboard, and to avoid a condemned chimney and studs (thimble is solidly placed). I have a call in to Duravent but waiting to hear back about elbow issue (still confused how one worked last year and now can't make the angle). Any help would be very welcome.
Thanks!
![Venting basement pellet stove issues Venting basement pellet stove issues](https://www.hearth.com/talk/data/attachments/286/286849-403b91b5ffd635012cfb2b1bece4d510.jpg)
Thanks!
![Venting basement pellet stove issues Venting basement pellet stove issues](https://www.hearth.com/talk/data/attachments/286/286848-acb946cb7e31c768874b4ac456a5d2f5.jpg)
