I have read and read and re-read anything I can find on the net about venting up past the smoke shelf in an existing chimney and still have questions. I am hoping the answers will show up here. I know that the 4" stainless pipe needs to be flattened to get past the damper IF the damper can't be dismantled. I also know that a dust shield needs to be installed with insulation on top of the sheetmetal and possibly caulked.
Question: How do you hold the dust shield in place? I was going to make a cardboard template and then cut the sheetmetal, glue the insulation on top of the cover, slide it in place and have four pins (bolts perhaps) slide into the bricks in 4 spots UNDER the shield to hold it in place. Think that might work?
Thanks
John
Thanks
John
